Need help with shift points
NA:
100 Hit:
So the question is, what rpm should I be shifting at running NA or on the juice?
The rev limiter is set at 6500rpm currently but looking at the NA graph, I am not making any more power past 59XXrpm. Also, on the juice, my power peaks at 52XXrpm and then trails down just a bit. I want to stay in the biggest chunk in power so again...looking for some info.
M6 car btw with 3.42's in the rear.
-Brian
We've done this a few times before. It is more of an art than science. Every engine/car will have a sweet spot. I was taught on my BBC, drag only, big rollers to start at 1000 above peak power.
Shift points are shift points. You do not have to change them from N/A to nitrous.
If you have a rev limit of 6500, shift at 6350-6400 - leave a little room for error.
I assume that you have the car tuned for both NA and nitrous??? Why did they cut the nitrous run short? In fact both dyno runs IMO should have been run to the rev limiter.
Good luck.
David
To do the caculation you need
(1) the spreadsheet rwhp data values of the runs, not the graphs.
(2) your tranny ratios for each forward gear.
Caculate for say 4500-6600 the delivered-rwhp in each gear.
Then look at the pre-shift delivered-rwhp at each rpm above the peak, and compare it to the post-shift delivered-rwhp.
You want to keep reving the motor higher so long as the delivered-horsepower pre-shift exceed the delivered-horsepower post-shift.
I did those calculations for all my stock Z06s and concluded that the ideal shift point for each car for 1-2, 2-3, and 3-4 is right before the limiter. So with a fast clutch leg, I target clutch-in for the rev-limiter minus 100 rpm.
I have verified these shift points at the drag strip and confirmed they are ideal in a stock Z06.
With that said, your results may vary from mine; but the procedure for determining the ideal shift point remains valid. Most dyno shops keep runs stored on their dyno-puter and can print out the spread sheet data for your runs.
Ranger
-brian
-brian
Where you shift depends on your objective. I'm trying to find the lowest possible ET in my stock cars. Doing that requires optimal shift points.
Anyone that shares that objective needs to do the calculation I've described. I've found a shift short by 300 rpms from optimal on the 1-2 costs about .15 seconds; the same on the 2-3 costs about .10. Those are big swings for shift point errors.
On the LS1 and LS6 motor, the tac lags behind actual motor rpm on the 1-2 and 2-3; so the driver must calibrate the clutch-in rpm to make the shift before hitting the limiter.
Ranger
If you're going by a shift light, n/a shift at 6100, nitrous at about 5600
-brian
My theory with LS1 F-bodies has always been 200rpm above the peak HP.
NA 6100
N2O 5500 [that is strangely low]
If the motor is still making more HP than it will post-shift, then don't shift yet. Simple as that.
The LS1/LS6 motor has a network speed that is much slower than the LS2/LS7. That means when the LS1/LS6 motor is in 1st and 2d gear the tac will lag behind the true motor rpm. So the driver must interpolate to get execute clutch-in just before hitting the limiter. 3d gear registers true however. The tac and the actual rpm coincide.
Those conclusions are based on my calculation, field checked by 500 passes.
Ranger
