Drag Racing Tech
PS delete come in quick
Old Jun 21, 2007 | 02:22 PM
05 GSXR 1XXX's Avatar
Default PS delete come in quick
so i took it off, and ive heard of looping the lines..
what lines do i put together?
i was just going to take the coolent lines going to it and plug them off, then just plug off the rack?
anybody have pics of this?
and can somone explain why the coolent lines even go to the rack?
Old Jun 21, 2007 | 03:45 PM
somone!???
Old Jun 21, 2007 | 03:52 PM
Razor_Blade's Avatar
You're not looping coolant lines. If you already removed the pump, there should be two hoses that go to the steering rack. Those are what needs to be looped.
Matt D's Avatar
Retired Street Racer
I will try and get a pic for you tonight or tomorrow.
Old Jun 21, 2007 | 06:08 PM
brandonppr's Avatar
I am interested in the pic too. Doing the same way, I think I know what to do but would like to see a pic.
Old Jun 21, 2007 | 09:58 PM
Kuhnstyle86's Avatar
its harder to turn than a manual rack when you use a power rack manually
Old Jun 21, 2007 | 10:11 PM
Josh@KY-Turbo's Avatar
How are you guys routing the belt when you delet the PS? I am ditching the PB for a manual setup when I put on the aerospace stuff, and may as well lose the PS too. Is there a custom idler I can buy somewhere?
Old Jun 21, 2007 | 10:33 PM
im only running a stock tensionor, alternator(located on driver head) and water pullie, and crank.
im using a 710 K6 belt.
just need to see how to loop the rack since the PS is gone
Old Jun 21, 2007 | 11:55 PM
brandonppr's Avatar
I am only going to be running the alt and nothing else. I got BMR's LS1 "Race" Alternator Mount Kit
Old Jun 21, 2007 | 11:57 PM
how do you get the alternator off if need be? no tensioner?
Old Jun 22, 2007 | 12:12 AM
6techniques's Avatar
unbolt it from the bracket.
Old Jun 22, 2007 | 12:42 AM
that would just seem kinda hard to force the altntr down and put a bolt thro it...
iono, ive never done race Acc's so let the learning begin!
Old Jun 22, 2007 | 12:49 AM
brandonppr's Avatar
See the bracket at the bottom? It slides and you set the tension then tighten the bolt kinda like an old school one.
Old Jun 22, 2007 | 06:16 AM
I like that setup, Too bad it gets in the way of my turbo pipes. I have my Alt mounted up top on the passenger side head.
Old Jun 22, 2007 | 08:43 AM
JFM-jr's Avatar
Is there a lighter/smaller alternator we can use with this setup? I have no AC,stereo is out etc... Was looking to drop some weight off the nose and this seems like a place to try.
Old Jun 22, 2007 | 09:33 AM
Matt D's Avatar
Razor Blade is right. There are two rubber hoses that you use a 3/8" hose mender to loop the lines, and you just throw hose clamps on it.
Here is a pic of what you need. 3/8":
Here is a pic of how to route the belt:
I won't have my car back from the chassis shop until tomorrow afternoon. I will get a pic tomorrow, but my alternator isn't relocated. All I did was delete the power steering pump, pulley, and the idler pulley, just like the pic above.
Old Jun 22, 2007 | 09:39 AM
Matt D's Avatar
Oh, and the wheel isn't THAT hard to turn with the stock rack looped. I can take turns one handed with skinnies up front. It will be harder with a stock 16" or 17" rim though. It looks real good without it
Old Jun 22, 2007 | 11:42 AM
wow, I really dig how clean the front of the engine looks w/o all the acc. running off the front of it...I wonder how many horses were regained by doing that.
Old Jun 22, 2007 | 11:51 AM
Matt D's Avatar
I like the way it looks too. I will be getting rid of the ABS here shortly, as soon as I get the time to run the new lines.
Old Jun 24, 2007 | 02:04 PM
SLPSS99's Avatar
Thats how I have mine run and works great.
Dan
