Drag Racing Tech
What times can I expect?
Old Jun 24, 2007 | 01:05 PM
Detoxx03's Avatar
Default What times can I expect?
With the mods in my sig I need an estimate on what my times will be cause I thinking of taking it to the track. Thanks in advance.
Old Jun 24, 2007 | 01:29 PM
Travose21's Avatar
Old Jun 24, 2007 | 01:30 PM
Travose21's Avatar
what do you have for suspension
Old Jun 24, 2007 | 07:07 PM
donkey mule's Avatar
Very low 12's - high 11's would be my guess.
Old Jun 24, 2007 | 09:47 PM
Detoxx03's Avatar
I'm in the process of working on the suspension right now.
Detoxx03's Avatar
So in other words it stock
Old Jun 25, 2007 | 03:36 AM
DietCoke's Avatar
Low 12s/high 11s with a tire. Mid-high 12s on street tires.
Old Jun 25, 2007 | 07:33 AM
darrensls1's Avatar
On street tires you would definately be in the 12's. If you have a decent drag radial and can dead hook then I'm guessing high 11's. Possibly even a mid 11 in good racing conditions and if you have 3.23 gears.
Good luck at the track and post up your results.
Old Jun 25, 2007 | 10:08 AM
Jakes Dad's Avatar
This won't win me any point, but since you asked a question I'll answer you.
I understand you don't like imports but I think you're missing out on some good racers.
From your post you want everyone to guess your ET. I assume since you didn't post that you've never been to the track with your car, you never have. I assume you've spent all your hard earned money buying stuff. Stuff on one car doesn't perform the same as stuff on another car. Sometimes all the stuff in the world doesn't yield the wanted return because the driver never learned how to drive their car. A 3,600 stall isn't worth a poop if you don't know what 3600 sounds and acts like on the car. I don't think you'll get into the 12's. I think you'll come back and post you thought you would do better. Everything you do to a car makes the car different. I think it's a waste of money to buy stuff without a final plan, subject to change. Plans change after you develop a bench mark, stock. Then based on testing you buy parts associated with addressing weak areas for your car.
I'll still wish you luck and please post your results.
Old Jun 25, 2007 | 10:17 AM
98CamZ28's Avatar
I understand but it sounds like he's driven the car before now so he should have a feel for what the stall and his car is capable of doing. I'm confident he'll put the car in the 12's on street tires, it might take him some passes to not overpower the tires on launch but he can dog it out of the hole and then get on it with that kind of power.
If you can hook your car pretty well (on a tire) you should be able to get decently into the 11's
Old Jun 25, 2007 | 11:37 AM
darrensls1's Avatar
I think you're missing two very important points.
1). He has dyno results. 387 rwhp in a stalled F-body is good for high 11's period. Whether or not he hits high 11's depends on the traction. If he has bad launches due to street tires then high 12's is still obtainable.
2). It's an automatic. He doesn't need to learn how to drive it. Driver error is all but removed from the equasion (after the launch at least). He only needs to learn how to launch it. And if he has M/T street radials then he only needs to learn how to floor the gas pedal after a burnout
I have a friend who's a member here that dynoed 389 rwhp in his stalled A4. With mickey thompson street radials he was able to get 11.92 @ 115 in not so favorable weather conditions. And I know his car has more in it then that.
Old Jun 25, 2007 | 09:51 PM
98CamZ28's Avatar
My old car had 361rwhp/359rwtq and went 11.69NA @ 115 on MT DR's and 3800 stall
Old Jun 25, 2007 | 11:04 PM
Duffster's Avatar
Old Jun 26, 2007 | 11:41 AM
darrensls1's Avatar
That's very impressive. Stalled autos are the shiznit
Old Jun 27, 2007 | 01:12 AM
chrs1313's Avatar
**** thats weak...jk
whats up with Jakes dad...am i missing something or should he just with his comments
Old Jun 27, 2007 | 01:44 AM
HTX's Avatar
HTX
With a big stall you NEED to have LCA's and a TA. With out them you wont hook for ****. Even on DR's. I know this from experience.
Old Jun 27, 2007 | 06:04 AM
darrensls1's Avatar
Not true. I dead hook very well on stock suspension and M/T street radials. So does my buddy who has a stalled auto that made 389 rwhp and dead hooks on the stock suspension.
I'm not saying that LCA's and a TA won't be needed for traction eventually. But for cars under 400 rwhp , M/T street radials can and have gotten good (even fantastic) results. I've been hearing good things about the Hoosier drag radials as well.
Above 400 to the wheels and I agree completely.
Old Jun 27, 2007 | 08:21 AM
HTX's Avatar
HTX
Well that was the story for me anyway. With only boltons and a 3200 VIG i spun all the way through first and a little in second (with Nitto's).
Then i boutght (around $750) a BMR Torque Arm, UMI Lower Control Arms and panhard rod. (SFC's were installed when TC was installed)
My launch was so much better and dropped .3 off my 60'
I realize i shouldnt have said it as if everyone else would have the same results, but thats my story.
Old Jun 27, 2007 | 08:49 AM
junior28570's Avatar
With the power he's making and that stall, non-DR's will most likely net a >2.0 60' and he's apt to have traction issues again going into 2nd .. high 12's IF 12's at all. Some DR's and he's easily in the 12's and some practice with the 60' .. high 11's .. just my .02
Old Jun 27, 2007 | 11:15 AM
CRZYPWR's Avatar
Really? What was it's race weight? What suspension?
Some nice times.
