Drag Racing Tech
M6 Launch RPM with a 9"
Old Jun 28, 2007 | 12:47 AM
RPILS1's Avatar
Default M6 Launch RPM with a 9"
my new (to me) 98 M6 is going to the track this weekend for the first time what should i launch it at i got M/T drag radials 255/50 and a ford 9" with 4.30s and 31 splines i figure the rear will take any abuse that drag radials will hold the car has a LS7 clutch stock i assume let me know what you guys think hopefully monday i will have the 11 sec club tag
Old Jun 28, 2007 | 01:20 AM
0camaro1's Avatar
leave when the valves start to float.
Old Jun 28, 2007 | 01:33 AM
Nimitz87's Avatar
experiment...leave at say 5500 and if it sticks bump it up, if it doesnt drop the rpm a bit...you have to play with it there is no magic rpm that we can tell you to leave at its all dependent on how you slip the clutch, and your susp. setup.
Chad
Old Jun 28, 2007 | 07:28 AM
c0ncEpT's Avatar
I was just about to say something like that
Old Jun 28, 2007 | 11:17 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
The higher it holds and hooks, the better. Some tracks will take more than others, so some experimentation may happen.
Good luck!
Derek
Old Jun 28, 2007 | 11:56 AM
trigger1's Avatar
Drag radial and stick is going to take a little more work than say a ET/drag or street. Use as much RPM as you can get away with. You also might be better off with trying to slip the clutch a bit rather than straight dropping it. Although that's not going to be the best for your clutch.
Old Jun 28, 2007 | 02:18 PM
Vents's Avatar
you'll be looking for a new clutch soon. just kinda play with it and see what the car likes. 4500-6500 some cars like more, some less. it takes some guess work at first but you'll get the hang.
Old Jun 29, 2007 | 12:54 AM
RPILS1's Avatar
yea i think im going to start around 4500-5000 and see what happens the track is only a drag strip on the weekends for the street racers but i heard they dump alot of VHT on the pad so we will see what happens
