Drag Racing Tech
Can I remove the upper panhard rod support?
Old Jun 28, 2007 | 09:05 AM
Z06kern's Avatar
Default Can I remove the upper panhard rod support?
I'm installing a new 9" rear end and wondering if I can remove the upper panhard rod support? This will be a drag car only. Has anyone else removed it? BTY, the car is a 94 Camaro.
Thanks
Old Jun 28, 2007 | 09:24 AM
Tony Shepherd's Avatar
You can remove it if you reinforce the lower panhard bar mount on the passenger side.
Old Jun 28, 2007 | 10:00 AM
HioSSilver's Avatar
yes, I removed mine over 2 yr ago. I moved my panhard up into the brace hole to make it level again, because the car is lowered.
Old Jun 28, 2007 | 10:49 AM
Z06kern's Avatar
Thanks for the replies. I have a wolfe moly adjustable panhard bar will that be enough reinforcement? Or do I need to weld a gusset inside were the upper bar bolted in?
Old Jun 28, 2007 | 11:14 AM
Jon@Texas-Speed's Avatar
You should be fine. I removed mine a couple years ago when I put my BMR adj. rod in. I drove the car daily for a while and had zero issues!
Old Jun 28, 2007 | 12:37 PM
I welded the seams and added gusset supports to it. I think you are playing with fire if you do not make sure that bracket is strong.
Old Jun 28, 2007 | 01:01 PM
Z06kern's Avatar
Thanks! I think what you are talking about is good insurance and that does not seem like its to hard to do.
Old Jun 28, 2007 | 02:00 PM
JL ws-6's Avatar
Race your car!
I just took mine out about 2 years ago and haven't had any problems.. but I don't street drive the car much anymore.... if you drive it alot on the street I'd probably leave it in, or reinforce it some.
Old Jun 28, 2007 | 09:38 PM
xpndbl3's Avatar
pics of reinforcement?
