Here are some pics of M/T DR 315 60 15 on car non mini tubbed
nice. i assume lots o cutting on the inner wheelhouse area?
i have the 325 m/t radials on mine. not sure if i will ever need the big 30 inch badboys. i cant see how i could fit the big ones in there at this point on my car
Getting 275 60 15s to fit will be a miracle. I am going to have to break down and buy some spacers.
Originally Posted by revtime
Thats no lie. I am having a hell of a time getting my 275 50 15s to fit with my shortened 2.5 inches on each side 12 bolt.
I just fit my car with welds 7.5 backspace. I took about a third of (outer)the bumpstop off. I ground the center out of the horizontal and vertical ribing and beat them flat. I then welded most of it back together. It gave me alot more room. My 28x10.5 et drags are ALOT wider on the sidewall than my 315x17 drag radials
Originally Posted by Nine Finger 02 Z28
Seems that you may have the wrong wheel offset for your setup.There is no reason for you to need spacers other than not having the right rim or the offset making it harder to clear the brake calipers.Seems that being shortened 2.5 inches that a 5 inch back spacing should work with a 10 inch rim.The 275 50 15 is a easy tire to get on our cars.
I almost have it licked, just a few spots need touched up.
I may have to run a spacer with the 28 inch tire though.
Do you have a picture of your parachute mount?
Your wheel pics look great, I'm guessing you did some rear bumper cutting, maybe an inch or so to fit the tire?
I've been able to stuff a 28W and a 325 DR on my car, works out to a 28x11.5 slick. I think I could fit 29.5's without doing too much work. My rule of thumb is to have 2 centimeters of clearance all the way around... I've never cut up a tire.
