Drag Racing Tech
what will improve performance the most
Old Jul 16, 2007 | 01:43 PM
nvrstsfd23's Avatar
Default what will improve performance the most
I have between 1500 and 2500 to spend on my car. I am looking to improve the performance of my car. What would be the best way to spend the money. I was thinking maybe some suspension work , gears, and a set of drag radials.
Old Jul 17, 2007 | 10:27 AM
thunderstruck's Avatar
with it being a M6 + drag radials + gears = rear end on borrowed time, but some people do get lucky
Old Jul 17, 2007 | 12:54 PM
Navy David SS's Avatar
M6 = good clutch + suspension (LCA, SFC, shocks, springs) + gears (min 3.9/4.10).
David
Old Jul 18, 2007 | 01:10 AM
CoozePoodle's Avatar
Gears/tire!! and super he-man N20 shot
Old Jul 18, 2007 | 04:50 AM
JL ws-6's Avatar
Race your car!
I'd but that $ towards a rear, with a stick car, it's only a matter of time, and if you put 4.10's in a 10 bolt, I guarintee you will break that soner then later, you've got nearly enough to pick up a 12 bolt...... I'd put that on the top of the list. With 4.10 gears in it, which will help alot.
Old Jul 18, 2007 | 11:55 AM
nvrstsfd23's Avatar
ok so scratch the gears then until I upgrade the rear end. Thanks for the input.
Old Jul 18, 2007 | 11:58 AM
JL ws-6's Avatar
Race your car!
just a good idea, better to spend the $ on a good rear once and have a fraction of the problems then it is to be breaking a knows weak link again and again.
Old Jul 18, 2007 | 02:21 PM
Omega Doom's Avatar
DR's,3.90-4.10 gears with a spool and better axles and a nitrous kit!
Old Jul 18, 2007 | 02:52 PM
joblo1978's Avatar
Since you're in the drag forum and looking at your sig, I'm guessing you want to improve on track times.
You need some suspension work. I would recommend SFC's, LCA's, and Anti-Squat brackets too. I think investing in the 10 bolt is a waste, but another rear end would put you over your budget.
If you turn your own wrenches though, you could get more.
I would most definitely recommend some BFG DR's, a shiftlight, and a line-lock as well.
No point in adding power when you can't put down what you have already. And eliminating the wheelhop will preserve your rear end a bit longer.
Old Jul 18, 2007 | 02:56 PM
Jakes Dad's Avatar
Wouldn't Nitrous help the most?
Old Jul 18, 2007 | 03:01 PM
brandonppr's Avatar
here are a few options
1
n20, LCAs, LCA relocation brackets, and tires but don't spray off the line.
2
a 9" rear with gears and tires
