I need help! Interior wiring ground???
. I hope I am just missing a ground and hope I can find it if so. Is there a ground on that side? Ask me how I know - http://www.1slowformula.com/HVAC-rad...lete/index.htm
The box that is buzzing, I don't think its supposed to buzz.
Also I don't have any of the engine wires hooked up only the grounds are grounded from the engine harness. The engine is not in the car now. The PCM is hooked up.
I will go out and double check, but I think there were 2 ground wires going to the driver side dash support bolt. there was a ground wire junction (6-8 black wires butt-connected) in the bottom loom, about the area behind where the HVAC controls were, did you touch that?
*** EDIT ***
Yeah there are 2 on the driver side post...
*** EDIT ***
I cut out the abs, AIR, EGR, radio wires, HVAC and I am sure there is something I am forgeting. I moved the under the hood fuse boxes to inside the glove box. I redid the headlight wires so they run under the fenders and are hidden.
Thanks for the help!
