Drag Racing Tech
Track Tonight Again
Old Jul 25, 2007 | 09:18 AM
camarokid94's Avatar
Default Track Tonight Again
clutch is startin to slip but ill be 200lbs lighter we will see what happens
Old Jul 25, 2007 | 10:26 AM
MARKSZ71's Avatar
good luck
Old Jul 25, 2007 | 10:59 AM
30th t/a's Avatar
good luck. im interested to see what you run. is the weather going to be better or worse than the last time you ran?
Old Jul 25, 2007 | 12:46 PM
i keep checkin but it looks maybe a little hotter and more humidity.
im lookin for 60ft gains since on the 2 3 shift it slipps prettty good
Old Jul 26, 2007 | 09:46 AM
well track was a wash i was spinnin in 2nd. i bogged the launch and it would plow them off at 4500 and half way in 2nd GGRRRR its called track prep guys come on.
did go 11.54 @ 125.73 i could tell takin the cutouts off and 200 lbs lighter helped.
Old Jul 26, 2007 | 10:41 AM
30th t/a's Avatar
what was the 60'?
Old Jul 26, 2007 | 11:28 AM
oh 1.91ish and that was john force peddlin style and some spin in 2nd enought to skate it around back and forth
Old Jul 26, 2007 | 11:38 AM
JL ws-6's Avatar
Race your car!
get some slicks on the car and get to a good track once your clutch issues are strait, you have a similar setup ( iron block vs my alum, and less compression) to mine, you should be running like the times in my sig. once you have it figured out.
Old Jul 28, 2007 | 06:17 PM
all i want is a 10.99 NA then ill give her the juice. i am gettin some prostars and a wolfe cage as well.
Old Jul 29, 2007 | 08:12 PM
donkey mule's Avatar
Nice times!
Old Aug 4, 2007 | 04:17 PM
went 11.309@125.51 last night tried the old 27in et streets i think i would heve had bettere luck with the drs. 1.75 60ft
Old Aug 4, 2007 | 06:11 PM
JL ws-6's Avatar
Race your car!
getting there.... give it some more time. what is the suspension setup/raceweight again?
Old Aug 4, 2007 | 06:28 PM
lol well thats where it gets tricky
3593 me in it.
front suspension stock with lowering springs.
rear spohn heim joint lowers chromoly/ tq arm -2.5 pinion angle/ stock springs cut to match the front lower height.
my plan is to do some front coil overs and rear drag shock.
Old Aug 4, 2007 | 07:02 PM
JL ws-6's Avatar
Race your car!
you've definately got some more potential in the car if that is the suspenion setup, those lowering springs never seem that great at the track from what I have seen.
Get some stock springs back on the car and some qa1 12 way rears, R series fronts, and see what that will get ya.
Rip the front swaybar off too, that will do wonders if you haven't already. Just don't drive like a nut on the street with it off.
Old Aug 5, 2007 | 01:13 AM
oh yeah sorry sway bar has been off......well since i bought the car in 04 LOL
yeah i need some suspension and.......stuff pretty much anything that will make it fast.
just raced a procharger TA and KILLED him so now i have a target on my back and there is a 10.85 auto 408 car commin for me.
Old Aug 5, 2007 | 12:19 PM
slow trap's Avatar
i have a set of 27" et streets also,dag gum our setups are so eerie similar. i have qa1 on the front already but when i took it to the track i didn't have my lca brackets on and left the shocks on full stiff. left at 5k and needless to say i think i seen a turtle hole shot me dropped the rpms down to 2500 and it finally pulled off a 1.7x 60' but i never got in a clean full pass to see what it is capable of. next time i'm going to set the shocks softer and hope for a 1.6 60' and maybe a 7.2x or 7.3x at 100 mph or so.
Old Aug 5, 2007 | 05:49 PM
yeah no kiddin its a bear to launch now with all the TQ
