Drag Racing Tech
Picking front shocks and springs
Old Aug 1, 2007 | 10:09 PM
cainsw's Avatar
Default Picking front shocks and springs
What is the correct way to go about picking springs? My car weighs 3300#'s with me in it. What would be the best shocks to use? This is a 99% strip car.
Old Aug 1, 2007 | 11:03 PM
1SlowFormula's Avatar
Most things I found say 275-300# springs for a drag race setup, I'm getting 275# springs and my car is 3190# with me in it...
Old Aug 2, 2007 | 04:23 AM
94z28L's Avatar
afco's i'd check with madman at thunder racing on what he would reccomend based on what stuff you already have done to the car on what is gonna work best
Old Aug 2, 2007 | 10:51 AM
dlove's Avatar
stock springs
Old Aug 2, 2007 | 11:23 AM
JL ws-6's Avatar
Race your car!
I would try the car with stock springs on it first. as for shocks, if ya have the $ go for the afco's, or strange. QA1's are what alot of people on this board run including myself, and they are a TON better then stock, and are pretty good $ wise.
Old Aug 2, 2007 | 11:35 AM
2002_Z28_Six_Speed's Avatar
275 springs are for cars approaching or at 3000 lbs. You will probably want double adjustable QA1.
Old Aug 2, 2007 | 12:27 PM
MADMAN's Avatar
LS1Tech Sponsor
Stay away from the double adjustable QA1s.
__________________
www.madmanandcoracing.com
225-343-9029
Old Aug 2, 2007 | 01:21 PM
dlove's Avatar
just wondering why you say that? I use the QA1 r's so im clear but i would like to know what issues there are with the double adjutables.
Old Aug 2, 2007 | 02:39 PM
MADMAN's Avatar
LS1Tech Sponsor
The doubles were designed on the R shaft and body. There isnt enough room to put a proper valve in there. Plus they leak twice as fast as the regular ones. If you are going to spend the money on a double then step up and buy Strange Or AFCO.
__________________
225-343-9029
Old Aug 2, 2007 | 03:15 PM
dlove's Avatar
good to know
Old Aug 2, 2007 | 03:37 PM
JL ws-6's Avatar
Race your car!
madman does that mean the R series are no good as well?
Old Aug 2, 2007 | 05:09 PM
cainsw's Avatar
What would the spring rate be on a stock spring? I'm trying to under stand how the spring rate is determined. What exactly does the 275lbs rating of a spring mean? Lol, maybe this is way over my head.
I have been running my car for years on full stock suspension thinking that suspension parts were a waste, then I changed the tq arm, installed some LCA relocation brackets and after one pass with'em I realized how much I need to work on the complete suspension setup
Old Aug 2, 2007 | 05:22 PM
dlove's Avatar
http://www.angelfire.com/my/fastcar/suspension.html
Old Aug 5, 2007 | 01:44 PM
How about single adjustable F series shocks? Front and back?
Old Aug 5, 2007 | 06:15 PM
camarokid94's Avatar
i need to know more cause my car sucks off the line and im lookin into front coil overs and rear shocks
Old Aug 5, 2007 | 06:31 PM
gator's 99TA's Avatar
stock front shocks, CE rears (the el cheapos) and BMR lowering springs (for looks). it works for me
Old Aug 5, 2007 | 10:14 PM
onfire's Avatar
Coal Mining Director
My stock fronts are 300lbs.
