every little bit??????
I think the main reason that most don't run an air filter is because they are rebuilt a lot more often than your normal car. There is plenty of trash/bugs to get into your engine at the track. My car is always covered in bugs on the front by the end of the night.
A lot of the guys I know refresh there engine every year so no filter is really no big deal.
As far as the rest of the stuff it should pick you up more than .1
like said before cooler weather will pick you more than all of that. cooler weather should pick you up about .4 when it gets into the 40-50s
I ran 28lbs in the same size dr tire. I can't remember my best 60ft but best et was around 8.2 NA back when I was running that tire.
