How does ride height effect launch?
Oh, the rears are stock springs minus the rubber insulator (heater hose mod) and adjustable Comp. Eng. shocks riding on 275 60 MT DR's (28" tall) so the rear has been a little higher then the front for a while...
Thanks...
http://www.gallery.smithspeed.com/di...bum=22&pos=181
http://www.gallery.smithspeed.com/di...bum=22&pos=182
http://www.gallery.smithspeed.com/di...lbum=22&pos=74
http://www.gallery.smithspeed.com/di...bum=22&pos=235
http://www.gallery.smithspeed.com/di...lbum=17&pos=82
http://www.gallery.smithspeed.com/di...bum=17&pos=306
And these are after the QA1 install. Yes, I know that it's too low, but I thought it was cool looking and took some pics like that.
http://www.1slowformula.com/images/a_little_low.jpg
http://www.1slowformula.com/images/a_little_low1.jpg
http://www.1slowformula.com/images/a_little_low2.jpg
http://www.1slowformula.com/images/a_little_low3.jpg
http://www.1slowformula.com/images/a_little_low4.jpg
It is currently 2.75" lower then stock, I was thinking of either splitting the difference and raising it up another 1.5" so it has a 1.25" drop from stock in the front, or just making it closer to a 1" drop if the launch will be effected at a lower point. But then again this car is mainly going to be a drag car (whenever I get the money) so whatever gets the better launch will probably be ideal, but I have no idea where to start, or if dropping the nose will help or hurt it...
-Mark
Have QA1's been there done that.
With 28" tires you won't want to go too low?
I have 26" and the car sits level. No problem with hook.
Don't believe the hype, the car won't settle much if at all.
Put it where you want it.
Drive it around a little and check it on a level surface.
Been there done that too!
-Mark
I was thinking the same thing, but wanted to see if that was true or not, or if it was noticable. So I guess I will be setting the front and rear ride height to be about the same, and checking how that looks. I think that is still doable, but here is the question...
Where are we worried about measuring? Fender lip height? Body height off the ground behind the front's and in front of the rear's? or measure both and split the difference?
Currently with no weight in the car it the front sits .25 lower then stock, but it's even front and rear. Should I have set it even empty or with the driver/weight in the car? Maybe I can have my wife and a few sandbags in the drivers side to set it that way, if I should have it even with weight in the car...
So the questions are:
1) Should it be set level from side to side with weight in drivers seat?
2) If set at 2 different heights to compensate for weight on the driver side does this effect suspension travel, weight transfer, or launch?
You're going to have to track test it and see how the car reacts and adjust from there.
Takes time, good luck!
