what makes a car get to the 60ft?
you need more power or more gear is what the problem is.
launching lower will not help ANYTHING. I had the same probs, i had the same suggestion of launching in peak torque, those launches sucked even more then the bogs off of the limiter.
think about it this way: if you launch off the limiter, the motor will pretty much immediately fall into peak torque and by that time it is already slightly moving.
i was going 1.59 60' consistently with 385/370 on teh dyno (through a t56) on my car back in the day. i ran 26x11.50x16 et streets as well as 26x10.5 et drags. i spun but that kept the rpms up high and not bogging. spinning is NOT a bad thing on a lower powered manual car.
fwiw my car 60'd exactly the same (1.69) before the cam, on a 16" et street, and with eibach springs and lg lowering springs. that was also prior to the 2 step without slipping the clutch. that was also prior to the dana 60-still on the 10 bolt.
