Drag Racing Tech
what makes a car get to the 60ft?
Old Aug 24, 2007 | 09:06 PM
  #61
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
12.doh@114 is a good start. What are you changing?
Old Aug 24, 2007 | 09:16 PM
  #62
ls2 bait's Avatar
adding some tfs 215's, ported fast 90/90, changing out to a qtp header, going with an sd tune and then the nitrous daves 90 mm plate but i want it to run good on motor before i start trying to get the n20 down. i did buy some 28's though for when i do run the n20. also put the battery in the trunk. everything else shouldnt effect the e.t.'s
Old Aug 24, 2007 | 10:05 PM
  #63
gator's 99TA's Avatar
why do you fear the gear? you have a 6 speed.
when i had a 6 speed i went from 4.10 to 4.56 gears. i went from 26 to 24 mpg. that didnt change my life.
Old Aug 24, 2007 | 10:15 PM
  #64
LS1curious's Avatar
I don't consider most 3 inch commercially avialable catbacks and y pipes good exhuast.
Originally Posted by GrannySShifting
I personally have seen very little gain over a good exhaust. 260+ dur hyd cam cars, 136 mph traps at 3500 lbs
Old Aug 24, 2007 | 10:34 PM
  #65
ls2 bait's Avatar
its not that i fear it-i just dont like it. i drive the car prob 4-5 days a week atleast and i cruise around town in 6th gear just to keep the db's down. im a girly man and i miss my dual/ dual that came on the car.
Old Aug 24, 2007 | 10:36 PM
  #66
ls2 bait's Avatar
i picked up 2rwhp/ 2rwtq with a open cutout behind my 4" mufflex merge pipe. id say that speaks volumes for my corsa catback. at my power level anyways.
Old Aug 25, 2007 | 08:47 AM
  #67
LS1curious's Avatar
Corsa makes a nice system. their corvette stuff is awesome.what are the specs on the camshaft your using exactly.
Old Aug 25, 2007 | 12:40 PM
  #68
i lost 0.5 mph b/w my cutout and my closed cutout and dual/dual when making 10.90 passes.
Old Aug 25, 2007 | 01:45 PM
  #69
LS1Tech Co-Founder
I'd run the SLP dual-dual and a cutout. Have your cake and eat it too.
What are the specs of that cam?
Old Aug 25, 2007 | 07:56 PM
  #70
ls2 bait's Avatar
232/234 .595/ .598 112+0
Old Aug 25, 2007 | 07:58 PM
  #71
LS1curious's Avatar
that cam should make some pretty good power. Try retunning the car with open exhuast. With that much overlap its gonna need a very low restriction exhuast system to work right. I would try cutting plugs for the tuneup as open headered wideband tunning is very hard to do withouth collector exstensions.
Old Aug 25, 2007 | 08:36 PM
  #72
mzoomora's Avatar
14 Second Truck Club
Thats what I have.
I have been tempted by the true duals, but I like the current sound.
Old Aug 25, 2007 | 10:07 PM
  #73
LS1Tech Co-Founder
Yeah that's a popular NA cam, there's more in it. Retune, maybe get a 90mm on there. Most of the folks posting big numbers also have 90mm intake and other stuff like that.
Old Aug 25, 2007 | 10:55 PM
  #74
ls2 bait's Avatar
already gotcha covered
Old Aug 25, 2007 | 10:56 PM
  #75
ls2 bait's Avatar
thats the exact same that i had with mine open on my z28 when it was running mid 12's.
Old Aug 26, 2007 | 12:51 PM
  #76
Nimitz87's Avatar
good info on this thread.
what is DH2 guys?
I'll be up at BMP on the 30th for their T&T night
running the same cam just non of the cool susp. stuff...yet.
by Christmas I hope to have a 9inch in.
Chad
