A4 SI guys? Launch help
You're certainly not going to run the same times @ 5000' elevation as you do @ 500'.
I'll pull a .00x if I leave on 3rd yellow.
I wish... the calculated alt here is normally 3800-4200'
I've been told by several people that the track in Mission, BC is damn near sea level and everyone runs 1 second to 1.2 seconds quicker there. o.0
I switched from 3.23's to 3.73s and still could get anywhere near these so called 'easy 1.6_ 60' times.
The best 60's out there on N/A cars can mostly be attributed to higher stalls (if you have the susp. / tires/ tq to make it happen). <-- A 4K+ stall should enable 60's in the 1.5's or lower.
