Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 06-21-2011, 01:44 PM
  #4101
ATVracr's Avatar
Originally Posted by Phil99vette
4.000" to 4.250"
Using a rough calculator its telling me I can drop 2-2.4# of boost on the hit and 6# down track and still net the same Hp/LB ratio.
I would love to be able to leave with 4-4.5# of boost. Would eliminate some issues we were having....
Ok its a secert size. LOL ... didnt know that.
Why are you trying to use less boost? were you having trouble keeping the motor together?
Did you dyno motor with no turbo? if not what kinda hp do you think it would make?
Old 06-21-2011, 01:51 PM
  #4102
7 Second Club
Phil99vette's Avatar
It was a 4.00, now its a 4.250. We dont have a problem with the motor, its getting the boost in quick enough, if the motor is mechanically able to make 10# of boost and you only use 4-5, than you can bring in that 5-psi pretty quick. If the motor can make 8 and you use 6, the boost wont come in as fast. It should make a solid 600rwhp at 30# of boost.
Old 06-21-2011, 01:59 PM
  #4103
ATVracr's Avatar
4.25 .. hell it will 60' good with no boost. LOL!
I see.
Isnt it something like every 16lbs doubles your N/A HP?
will you put 30lbs on this motor? if so it should run OK.
Old 06-21-2011, 02:03 PM
  #4104
7 Second Club
I see.
On most motors you can double the HP at 14.7# of boost. We intend on running 35-45# of boost or so at 2900-3000#. How fast will it go to the 1/8 mile? What do you think the motor will make? 700-850?
Old 06-21-2011, 02:25 PM
  #4105
ATVracr's Avatar
2500+hp ... neat. LOL !
850-900+ depending on compression & cam.
We made 968 with no sheetmetal or dry sump... on C23 and #10 plugs
I'm sure we could have got more but we dont race dyno's.
Old 06-21-2011, 04:54 PM
  #4106
Wnts2Go10O's Avatar
any idea what part of the compressor map youll be running or is that secret because of the wheel?
I see.
because you are effectively causing a 200% VE at 14.7# you effectively double the size of the engine/double the power with boost. would be neat to see the dynamic airflow and cylair numbers when its buttoned up.
Does turbo motor work the same way our N20 motor does?
More cubes with same jet = easier on the parts ... thinkin maybe not for boosted motor.
isnt N20 a set amount on the same pill? because boost numbers are resistance to airflow, the better the engine breaths, the more power you make at the same boost level. hed be able to lower the boost level to make the same power.
i think the engine size and compression is 2-3 pages back..lol
Old 06-21-2011, 05:19 PM
  #4107
7 Second Club
I have not seen a compressor map for any turbo over a 101mm....
Old 06-21-2011, 06:58 PM
  #4108
Wnts2Go10O's Avatar
hm, id think something like that would be useful for what you want to do
Old 06-23-2011, 10:39 AM
  #4109
7 Second Club
Got all of the remaining water system parts fabricated this morning, distributor showed up, intake should be done today or tomorrow and still need the fuel pump.
Basically I've got:
Ic pipe
possibly firewall modifications
finish up the water system
and some small odds and ends.
Old 06-23-2011, 03:18 PM
  #4110
fenton06's Avatar
ETA for test hits?
Old 06-24-2011, 02:20 AM
  #4111
98 StealthZ's Avatar
calling all cars, calling all cars be on the look out for the FED EX truck carrying Phils parts, lets have a search party. I want to see him smack that pony in the *** and see what all of this new super secret high tech stuff from Virginia Speed is going to do...
Old 06-24-2011, 08:41 AM
  #4112
7 Second Club
Originally Posted by 98 stealthz
calling all cars, calling all cars be on the look out for the fed ex truck carrying phils parts, lets have a search party. I want to see him smack that pony in the *** and see what all of this new super secret high tech stuff from virginia speed is going to do...
x100000
Old 06-24-2011, 12:14 PM
  #4113
Wnts2Go10O's Avatar
at LEAST 12s at 160
Old 06-25-2011, 07:43 AM
  #4114
7 Second Club
Not really much to say...
Old 06-25-2011, 09:33 AM
  #4115
Broke EF's Avatar
Artwork as usual from Mr. Marcella! I cant wait to see this thing all wrapped up and making passes!
Sean
Old 06-25-2011, 01:20 PM
  #4116
WKMCD's Avatar
Truly a thing of beauty!
Now, get to work!
Old 06-25-2011, 07:49 PM
  #4117
GAP Racing's Avatar
Looks Awesome
Old 06-28-2011, 10:44 AM
  #4118
fenton06's Avatar
Shouldn't be long now...
Old 06-29-2011, 09:10 AM
  #4119
7 Second Club
Intake should be here today!
Old 06-29-2011, 09:12 AM
  #4120
7 Second Club
What intake gaskets are you using? We wont have time to o-ring them...
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
