SFI 25.2 Mustang/LSx build "The Renegade"
#4324
I've been doing I little bit of learning on this subject as well. From what I have found it has a lot to do with the internals of the dry sump pump as well as the size of each stage. Weaver Bros. and SCP "stock car products" for example use gear type internals as some of the other brands use lobed and twisted lobed designed internals.
Here's a few pics of the gear type dry sump. Notice #5, these are the gear type
![](http://i522.photobucket.com/albums/w347/DaCajun_2008/rep.jpg)
And now the lobed type
![](http://i522.photobucket.com/albums/w347/DaCajun_2008/pumpcomparison.jpg)
And the twisted lobe
![](http://i522.photobucket.com/albums/w347/DaCajun_2008/twistedrotor.jpg)
As like anything else there are advantages and disadvantages to both.
But I think Phil can add an a couple of A/C compressors along with a fricken 75kw generator to the front of that motor and still hurt a lot of feelings out there!!!
Can't wait to see that car make some clean passes....![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
-Dave
-Dave
#4327
Dailey Pumps is where it is at. They make some killer stuff. It is not cheap but hell at this point what is.
http://www.daileyengineering.com/
#4339
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
phil...don't be too rash. Mine leaked like a **** until I solved the underlying problem. IMHO, sending it back will result in a "fixed" turbo that leaks just as bad, therefore wasting your money
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
