nitto drag radial tire pressure
i have a set of 315 nitto drag radials and going to the track with them for the first time and was wondering what a good starting point for tire pressure would be and if the respond better to higher or lower tire pressure? the car is an 01 t/a a4 with 3.23 gears and a 3000 tci convertor.
I'd start at 20psi at the track. I run 26-28 on the street.
https://ls1tech.com/forums/southern-members/680191-what-psi-do-you-run-nitto-s-dr-s-street.html
