The stickiest tire poll.........
Lets hear it. What tires do you prefer to drag with? I'm running 15x8 Prostars with 27x10.5 M/T ET Streets right now, but am thinking about trying out a pair of 28x11.5 Hoosier QTP D.O.T.'s. I need something sticky...I'm running about 475 to the wheels with the help of a 150 shot of gas, going through a T-braked TH400. Please keep in mind, they have to fit on a 15x8" wheel and be D.O.T. approved. And no, I will not use Nittos.
my vote is the 28x9 m/t et drags as they fit on the 8" rim well and will take the hit of the brake.
summit was out, so i went with MT's this time.
It'a all in the suspension setup.
MT drag radials are great IF you go off the footbrake on an auto although some have had success off the t brake and m6.
The tire that worked best for me and they are not used by many (maybe just me
) is the Goodyear D3 slick. I ran 28x11's. They are a hard compound slick made for 3000 lb+ cars like ours. Off the transbrake N/A I consistently ran low 1.3 60's in the cooler weather w/a best of 1.32.These tires held even on cold days, I'm talkin' 35 degrees, COLD!
I would never spin on those tires unless it was super hot out and I wasn't making enough power to get the fronts high enough to keep the tires from unloading and even then I was in the high 1.3's.
I can't say enough about those tires!
Hope that helps some.
