Drag Racing Tech
TOO low of fuel for drag strip???
Old Sep 13, 2007 | 09:37 PM
nickdotcom's Avatar
Default TOO low of fuel for drag strip???
a guy i work with told me to not get too low on fuel at the track because it will go into open loop.
this didn't make any sense to me but i thought i would check just in case
Old Sep 13, 2007 | 10:16 PM
camarokid94's Avatar
nope makes no sense to me, and im ASE master, so i say no!
Old Sep 13, 2007 | 11:09 PM
Matt D's Avatar
Retired Street Racer
Old Sep 14, 2007 | 07:37 AM
jmill96Z's Avatar
I guess my question is, at WOT isn't the car in open loop anyways?
Old Sep 14, 2007 | 11:58 AM
badpewter-z's Avatar
LS1TECH Sponsor
it is in open loop under WOT anyway but if the tank is close to empty the pump may come close to running dry and lean out the motor. the bucket holds a good amount but still not enough for me to feel comfortible .
Old Sep 15, 2007 | 06:21 AM
Mark98SS's Avatar
I don't go lower than 1/2 tank for fear of lean out & pump damage.
Old Sep 15, 2007 | 07:51 AM
NHRAFORMULA00's Avatar
i run my car with only 1/8 too 1/4 for the past 5 years.NO PROBLEMS!!
Old Sep 15, 2007 | 08:52 AM
Jakes Dad's Avatar
Sounds like he is with you.
I wouldn't get too low on fuel, anytime, because I don't want to pull any dirt out of my tank, cloging my filters and injectors with dirt. I don't want my stock fuel pump, normally located in my tank, to be out of the cool fuel too long because of heat. Some people will place a tank in a new location to gain balance.
Old Sep 16, 2007 | 10:17 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
as mentioned above, too low on gas can create headaches on dirt in the tank, fuel sloshing away from the pickup during a launch that may produce air in the lines, etc. I've run with 1/4 tank before but no less. I usually run 3/4 or more (extra weight back there for helpm in the hooking dept if needed on a slick track).
Derek
Old Sep 16, 2007 | 03:40 PM
88blackgt's Avatar
running it low will eventually kill the pump. it is lubricated and cooled by fuel, so no fuel and it will burn itself up.
