PA light weight spindles?
CF-4900 2" Drop Spindle Struts 4th Generation $1099
The Strut spindles use a 3rd gen strut assembly with a plate at the top for proper travel geometry, they also require 3rd gen brakes, and AJE's custom lower arms for use with the strut.
the Replacement spindles keep the upper and lower a arms and stock and require 3rd gen brakes. last time i talked to the guys ate AJE they where around $600 for the replacement spindles.
I also wonder if they will make these without the 2 inch drop built in.... I mean I guess I coudl crank the springs up to get the ride height back, but that would act like a set of travel limiters I think and would do other things to how the car works, any input in this?
i was just going by what i was told when i called.
I had this all on the car a while back but ended up missing a few parts and got tired of waiting so I took it off and put the old stuff back on to run to car. I never had any issues at all, was able to align it with no problem, got the bump steer to zero easily, akerman was a little off but nothing deastic. But they kept sending me the wrong piece to extend the right side of the rack and pinion so I couldnt drive the car. But AJE tends to change things around pretty often, the k-member, lower a-arms and spindles look different than the same setup I seen on another car.. Not to mention I still dont have all the right parts here for it yet to finish it
I don't like hearing that part, about still waiting for parts.
I'm gonna go with their stuff because it's a little more racy, and should be a little lighter, I think for now I'm gonna run the stock spindles, unless those spindles are 10+ lbs lighter it's not worth the 1000 bucks for them to save 300 on the brakes. The stuff will go on over the winter and if for some reason I can't get something from them I think my fab guy probably could make whatever, but it would be nice if they had a complete kit that was 100% and worked. But, in aje's defense, everyone else's stuff has issues with something, geometry being wrong, bind in the steering shaft because of the angle, etc.etc. I dunno what I would rather have, a gemoetry problem that has to et redesigned once you have it, or to have a missing part a fab guy could come up with. I guess both aren't all too great, but one seems like an easier fix then the other.
If you're interested in some trick stuff check out www.racecraft.com. They've got some complete suspension setups with drop spindles that are very light and work very well.
-Ben R
