Drag Racing Tech
PA light weight spindles?
Old Sep 29, 2007 | 03:13 AM
ls1408cp's Avatar
Default PA light weight spindles?
A friend found these. http://paracing.com/index.php?cPath=...1a8f7cb70df3df
It says they weigh 6.5 pounds each I wonder how much the stock ones weigh? I sent them an email 4 days ago and never got an email back.
Old Sep 29, 2007 | 03:20 AM
daniel6718's Avatar
good find...post back up when you find out something
Old Sep 29, 2007 | 05:46 AM
1FST99Z's Avatar
looks like a nice piece.
Old Sep 29, 2007 | 05:49 AM
JL ws-6's Avatar
Race your car!
Please keep us posted when they get back to you. I couldn't see the picture either.
Would be nice if you could get those spindles that would allow you to use 1st gen style strange drag brakes, they're way cheaper then the 4th gen ones.
Old Sep 29, 2007 | 12:40 PM
ls1408cp's Avatar
I dont think they are going to email me back. I cant see the picture either. Maybe Thunder of another PA dealer could look into it.
Old Sep 29, 2007 | 01:11 PM
kp's Avatar
kp
I have the AJE spindles, they use third gen brakes.
Here is what the AJE looks like, been to lazy to swap it all and I'm still up in the air about losing my power steering.
I would bet between my MS PA K-member/stock spindle/UMI CM lower arms/aerospace brakes and the CM AJE K-member/manual rack (and loosing the PS pump)/AJE lower arms/AJE spindles/wilwood 3rd gen brakes its less than 20 lbs difference total. I assume the PA ones are similar, not a huge weight savings but you can get a drop spindle and it looks better then the stock stuff anyhow. If you have a super low car the drop would be more important than the couple pounds of weight IMO.
Old Sep 29, 2007 | 01:35 PM
ls1408cp's Avatar
How much does a stock spindle weigh? My car is in Chicago so I cant weigh mine.
Old Sep 29, 2007 | 01:41 PM
daniel6718's Avatar
i would guess a stock spindle is about 12-15 pounds each...never really weighted though...that part would be NICE for a bolt on change for lightening the front of your f-body...id be interested in what material its made from ect...some1 weight stock spindles!
Old Sep 29, 2007 | 01:42 PM
kp's Avatar
kp
I dont remember offhand, I had all the stuff off the car a while back and the spindle without the hub/bearing wasnt very heavy so I'm just going by feel. I am going to put one of these fabricated ones on a scale when i go to the garage later. I think they weigh more then the PA weight listed.
Old Sep 29, 2007 | 02:31 PM
kp's Avatar
kp
The AJE ones I have here are 10.5lbs each. If the PAs are indeed 6.5lbs then thats a pretty significant difference. I dont think these AJE's are much lighter than stock really, main reason I did them was for the drop if I mini tub the car.
Old Sep 29, 2007 | 07:54 PM
JL ws-6's Avatar
Race your car!
I wasn't aware that AJE made a spindle too.. I was planning on doing their k memebr and upper/lower a arms adn manual rack all at once over the winter, the spindles would be nice, and if I could indeed bolt up 3rd gen brakes the cost savings over the 4th gen vs the 3rd gen (going with strange front and rear) would probably cover alot of the spindle cost.
Old Sep 29, 2007 | 08:56 PM
kp's Avatar
kp
Honestly I ordered all this over 4 months ago and I dont even remember what it all cost anymore, it came with wilwood brakes but its just a regular 3rd gen brake kit according to the part number. I would imagine you could use strange if you wanted to - I'm not real picky about matching front rear brakes.
Old Sep 30, 2007 | 06:04 AM
JL ws-6's Avatar
Race your car!
I am not either, but beign able to lose some weight on the spindle, and save a bunch of $ over the 4th gen strange is a big deal. Just depends what the spindles cost.
Old Sep 30, 2007 | 06:13 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I wonder how durable those would be on the street?
Old Sep 30, 2007 | 07:05 PM
JL ws-6's Avatar
Race your car!
probably not very
Old Sep 30, 2007 | 08:41 PM
tektrans's Avatar
Looks real nice.
Old Sep 30, 2007 | 11:08 PM
OWN3D BY MY PROF!
probably not very
That's what I was thinking.
Old Oct 1, 2007 | 08:40 AM
Fireball's Avatar
this is very interesting...I like the fact they offer them with a 2" drop....question is what does it cost to have them set up for a 1st gen brake setup...
Old Oct 1, 2007 | 09:11 AM
fash00's Avatar
Unless im reading correctly which i probably am on AJE's site
CF-4900 2" Drop Spindle Struts 4th Generation $1099
Old Oct 1, 2007 | 09:41 AM
MADMAN's Avatar
LS1Tech Sponsor
I used the AJE spindles on Pacos car. I wasnt impressed and spent alot of time reengineering them to get the travel etc correct. I havent seen the PA stuff so I dont know about the quality of theirs.
__________________
www.madmanandcoracing.com
225-343-9029
