how much weight does minitubing an Fbody save?
You can move the control arm between the frame rail and bracket, this will give you an addition 1 3/4" - 2"" or so, but you will have to cut the sheet metal next to the seat to make clearance because the floor sits very close to this area but I am going to do mine this way, I explained it in another post and you will have to move the shock mount and rear control arm mount in.
With this done you will have a true 16". I have all of my tubs cut out now and set up to make 16" and the control arm will sit behind the tub from my measurements.
I finished the drivers side today, there is a ton of stuff cut out, I have a nice pile going into a box to weigh. Should finish the passenger side tomorrow then I will weigh what I removed.
I will also weigh the tubs and metal I cut to box in the frame. I doubt I'll be able to weigh the silicone and welding so that's as good as it will get.
I will run a piece of metal from the LCA mount up to the anti roll bar bracket where I cut up to and box it off. This cut out section will actually be on the inboard side of the tub.
I cut to the frame and it looks like I'll have close to 1 1/2" - 2" more clearance depending on how thick I make the spacers for each side with the LCA mounted in between the factory bracket and frame.
The way I am doing it still retains the stock bracket so guys that must run their LCA's in the stock bracket in the front still have the bracket to do so.
I am making a double adjustable bracket in the rear for mine, it will have 3 or 4 holes with 3 or 4 hole behind those so you lengthen the bar to reach them, this gives you 6-8 holes to adjust vs. the 2 most people run, mine will also only drop the LCA about 1/4 - 3/8" per hole.
Also note that you will have to relocate the factory shock mount. I plan to integrate mine into the rear LCA bracket so it will sit just above the top hole and will mount sideway so the shock pivots on a bolt vs the factory way where it mounts facing forward and binds.
Angle grinder died, taking the rest of today off.
Finished the drivers side cutting, cut the tub as close to the factory gas fill tube as I could, unlike a lot of the other cars my drivers side tub will be bent 90* in the back to line up with the factory body, so it will look square in the back and round in the front, passenger side will be round.
Mini tubbing is a hassle to say the least, it was much more straight forward last time I back halfed my other car.
Should finish all of the cutting tomorrow. Then I will weigh the stuff(have to borrow a scale), I have a pile of metal even the little shavings, so I am doing my best to weigh this crap.
i don't know if you've removed the seat brackets yet but if you haven't it's easier to drill out the spot welds and just hit them with a hammer than to try to use a angle grinder or sawz-all to get them out.
any pics of it w/ the interior back in the car??
also, i've heard of some people cutting an inch off the width of the tub. This way you can put the plastic interior back in the car w/ out having to cut it to fit the tubs. This would keep the illusion of the car being stock when looking on the inside and not being able to tell its been tubbed.
anyone else done this?
Cut out a section to make room for the relocated LCA.
I have the full 16" tub and the LCA sits behind the tub about 1/4" so by moving the control arm in I picked up 2" of clearance.
I will take photos before I put in the tubs.
Before the offset LCA was exactly 14" from the outer fender lip to the LCA itself. Now it is 16 1/4" from the fender lip.
Tomorrow I will put all of the pieces in a box and weigh them when my friend brings a scale.
Any guess how much all of the stuff I cut out will weigh?
It's for larger tires and everyone is curious how much the metal weighs, vs. how much the new metal and tubs weigh you put back in, so I am going to weigh both, besides I am sure every one takes a lot more weight off the front than the back, so it is not like it is going to hurt the weight distribution.
