how much weight does minitubing an Fbody save?
The factory wheel wells are not double walled and weigh nothing. The sound deadener/under coating and seam sealer combined with the weight of the factory tubs is probably still lighter than bare aftermarket tubs.
And I am not including tire or bracket weights because this post is about weighing the factory tubs and cut out metal vs. the new tubs and boxing in the frames and reinstalling the mini tubs.
Also I know a way to relocate the front control arms about about 1 1/2 almost 2" of clearance so you can get the full 15-16" of the mini tub.
https://ls1tech.com/forums/tools-fabrication/530117-wolfe-mini-tub-kit.html
https://ls1tech.com/forums/drag-racing-tech/582854-mini-tub-fab-9-everything-going-now-some-issues-pics-soon.html
The factory tubs are pretty thick compared to the after market tubs I got. They look almost like 1/8th" steel.
What a f'ing hassle, I forgot what hot metal shaving feel like =/.
I just got info from wolferacecraft.com install photos and just measuring and cutting to the same points as theirs.
I have exactly 16" from where I cut to, to the fender lip. Should finish all my cutting tomorrow.
Also the rear upper fold down seat and seat belts won't fit, the mounts get cut off.
I am going to have my seat cut down and remount the seat belts so I can still have a back seat but it looks like it will have to be about 3" narrower on each side.
