Drag Racing Tech
Bogging off line TC or ABS?
Old Oct 18, 2007 | 11:01 PM
ls1builderss's Avatar
Default Bogging off line TC or ABS?
Im having a bogging issue off the line and Im leaving at 6000 rpm. here is car
tsp forged 370 11:1 comp
prc stg 1 heads
ms4
42lbs inj
racetronix 255lph
90/90
LT's
3.42 rear gear
et streets & skinnies
spec stage 3+
UMI TA, LCA, & relocation brackets
powerbond
afr @ 12.5
Car dynoed at 480rwhp and when I side step the clutch at 6000 it dead hooks and falls on its face then the Traction control light comes on and finally it picks back up & pulls hard. Could this have something to do with the abs and TC light? best 60' was 1.78 and 11.97 @ 118. I know there is way more in it and it should be low 11's if not 10's if I could just figure out this bogging crap. Any help is appreciated!
Old Oct 18, 2007 | 11:21 PM
chrismorales75's Avatar
Turn off the traction control.
Old Oct 18, 2007 | 11:25 PM
well I guess I should have been more clear, there is no tc button. So does it need to be done with the tune.
Old Oct 19, 2007 | 07:01 AM
2_wacko's Avatar
What size rear et streets do you have also might want to run a lower gear in the rear.
Old Oct 19, 2007 | 07:28 AM
silver-mod-o's Avatar
Custm2500's #1 Fan
do you still have the trusty ole 10B on that thing? the TC may be saving it pull the fuse for the TC/ABS.... problem solved.
Old Oct 19, 2007 | 09:42 AM
they 27" et streets. I think it may be a mix between the tune (timing) and the TC but didnt think to remove the fuse. I will try that and report back. thanks for the help!
Old Oct 19, 2007 | 12:41 PM
smokinHawk's Avatar
i had the same problem with mine, ended up ripping out the ABS, that fixed it.
Old Oct 19, 2007 | 12:48 PM
The ABS makes since I've had the ABS light come on after doing my burnout and coming to a stop after rolling out of it. Is there a sticky somewhere on the ins and outs of deleting the abs setup?
Old Oct 21, 2007 | 10:59 PM
skeels's Avatar
I took my back 2 tires off and simply unplugged the sensors when mine was messing up after a 9" install. Problem solved. Only annoyance is the ABS INOP light that will stay on, but if it bothers you that much take apart the dash and pull the bulb. I just zip tied mine somewhere, i think maybe to the ebrake cables? Cant remember, just make sure you ziptie them that allows for suspension travel.
