anti roll bar...
Kinda have an answer/issue for everything dont ya Chris?
What's next I know you are but what am I or are you going to kick my *** or call my mom fat. LMAO
What is stated is that people running large tires that want them tucked in will not be able to use this product right or wrong?
Will a 315 60 15 on a 15x12 fit with the tire tucked in 1.5 - 2.0" from the fender lip? No.
Did I say don't buy this product it is junk? No, I stated concerns for the effects of the new loads placed on the panhard mount and it using the stock panhard bracket will limits it's future use if someone goes and runs a larger tire.
If that offended you that's your problem, I come here to to learn and share what I know, if you don't like that guess I don't know what to say.
I think it is a nice looking product, but unlike some people I want to know about what I buy before I buy it, I am not adding a part to my car, I am putting my life in some one else's design when I run down the track.
So I will make sure it is safe and effective before I go around telling everyone to buy it because it is just so great.
Again, this piece is intended for "stock suspension" or "bolt on suspension" type cars. Tucking a 315/60 radial in 2" inside of the outer fender lip is going to need other modifications that will put the car well out of the realm of a "bolt on suspension" car (and it will look goofy to boot in that far, just my opinion). The car that I am mentioning that this piece will be tested on is a 7.70 Radial Tired 84 Camaro with 315s (thats shown potential to run 7.50s after some 1/8th mile testing). Is that a fast enough car to test this on? I would consider him to have "large tires" on the car so I am kinda missing your point about people with large tires not being able to use this piece. If a person is going to go through all of the work to make a 12" rim, 315/60 radial combination fit on a 2" narrowed rear end they will also be moving the LCA points in as well as move the panhard rod brace and move the shock mounting points thus making their car completely illegal for any "stock suspension" racing and this type of setup is not needed when guys are already going mid 7s without all of that extra work.
Thumbs up for coming up with something new, good luck with it.
you got me.
