launch rpm with a 3,600 and 3.73s
I am guessing you are running an auto? A lot of cars vary, some leave off idle and try to flash the converter, some people will preload the suspension as much as possible. What is your 60ft?
Race your car!
There really is no guarintee'd way that will work. If you are getting 12.xx leaving at 2000, first thing I would try is pulling up and just stab it right off idle and see what it does, if it doesn't spin it should go faster, at least my car does. If you're having traction issues then loading it up some more might help, in that case bring it up as high as you can without pushing thru the brakes.
Car has M/T drag radials (20lbs), QA1s on back set at 3, random technology adj torque arm set at -3 degrees pinion angle and Hotchkis lower control arms. Front susp is stock.
Race your car!
If you can get a set of shocks for the front, the tires are good and the suspension settings are about right too. if you put the adjustable on the front, set them to 3, and put the rears to 5/6 right rear one stiffer then the drivers side, that will help keep the car level.
If you go to the track again with the car the way it is, pull the front swaybar off, and try stiffening the shocks a couple clicks, if it still hooks with the shocks stiffer it should be faster, less wasted energy on suspension movment.
If you are running the stock rear be careful flashing the converter. I broke three diffs doing that with 3.73s in the stock 10 bolt. brake torqueing is much better on the stock rear....
