Drag Racing Tech
abs delete / manaul master pics?
Old Nov 7, 2007 | 08:52 PM
SSPerformance's Avatar
Default abs delete / manaul master pics?
Looking for some pics of how u guys did the brake lines i have 4 channel so i wana make it look as clean as i can
Old Nov 7, 2007 | 09:22 PM
Steve Burger's Avatar
LS1TECH Sponsor
Check Burkhart's site.
Old Nov 8, 2007 | 06:39 AM
no pics of it
Old Nov 8, 2007 | 06:54 AM
brandonppr's Avatar
Here is mine. I deleted ABS using SMJ's kit(I rebent most everything and added 1 more line though) and I have a line lock and a proportioning vavle. I don't have manual brakes but I don't think it would be much different if I did.
more at: http://one8thmile.com/2007.html
Old Nov 8, 2007 | 07:40 AM
jmill96Z's Avatar
Where is the line lock?
Old Nov 8, 2007 | 09:31 AM
TwoFast4Lv's Avatar
I did mine off the SJM directions
Where the ABS used to be
Old Nov 8, 2007 | 10:27 AM
DMH Fabrication's Avatar
There was a thread not too long about with a lot of pictures of how people did this also. You may want to try searching since the search works now.
Old Nov 8, 2007 | 02:57 PM
do you need the proportioning vavle with manual brakes
Old Nov 8, 2007 | 09:38 PM
brandonppr's Avatar
It's in the 5th pic, its on the bottom of the driverside frame rail.
Old Nov 8, 2007 | 09:44 PM
daniel6718's Avatar
ellis i though you still had abs? guess since im going to be on the streeet a lot less i might be removing mine...
Old Nov 8, 2007 | 11:27 PM
Hawkn01's Avatar
I had the Strange manual master cylinder and drag brakes front and rear. You don't need the propertioning valve.
Here's a picture, it's large but you can see the master and line lock in the back along with the ABS delete block that Jay Billingsly sold.
Old Nov 9, 2007 | 12:38 AM
NSTY WS6's Avatar
I made my own kit....
Old Nov 9, 2007 | 03:26 AM
jmill96Z's Avatar
Ahhhh. I see it now. Thanx
Old Nov 10, 2007 | 08:14 AM
tektrans's Avatar
Default pics abs
here are a couple of mine w/ a bracket I made for the abs block.
Attached Thumbnails abs delete / manaul master pics?-abs.jpg   abs delete / manaul master pics?-abs1.jpg   abs delete / manaul master pics?-abs2.jpg
Old Nov 10, 2007 | 11:07 AM
SLowETz's Avatar
SJM ABS delete/Hurst line lock-
Old Nov 11, 2007 | 07:11 PM
John_D.'s Avatar
fyi, the lines come out of the other side of the master cylinder when you go manual.
Just a minor difference compared to most of the pics posted in the thread.
Old Nov 11, 2007 | 09:10 PM
phoenix's Avatar
whoa nice enigne bay!
Old Nov 12, 2007 | 08:58 PM
zigroid's Avatar
did you guys that pieced parts together rather than buying a kit, do you think it was worth it after it was all said and done? I want to do an ABS delete/line lock but the LT1 SJM kit is kinda expensive.
Old Nov 12, 2007 | 11:51 PM
TwoFast4Lv's Avatar
It was there until the last time I went to the scales
I am $75 into it
Line lock from Jegs $39.95 and the Bias valve for $26 to my door off e-bay
Old Nov 12, 2007 | 11:58 PM
daniel6718's Avatar
75 just to get rid of the abs? hmm id prolly do all custom lines for the front...and leave the rear alone...
prolly go with some strange brakes at the same time...
any noticable differance between power and manual brakes?
