Drag Racing Tech
got into arguement on tire PSI for radials
Old 11-12-2007, 11:55 AM
cam
cam's Avatar
it tends to shake and hop real bad if you cant hit it with a ton of power.
I have noticed this a bit but not terrible in my case
Old 11-12-2007, 12:41 PM
LS1TECH Sponsor
CutlassRacer's Avatar
275/60/15 MT Radial on a 8" rim 21 psi 1.52 60ft at 3450 pounds
315/60/15 MT Radial on a 10" rim 14psi 1.26 60ft 7.74 @ 186 mph at 3400 pounds
Old 11-12-2007, 01:56 PM
rtk434's Avatar
275/60/15 on a 9" wheel...17 psi..1.279 60'
295/65/15 on a 9" wheel...18.5 psi...1.275 60'
Old 11-12-2007, 04:33 PM
cbra-klla's Avatar
I usually run 20 -22 psi but have cut mid 1.5's with 25 lbs in my m6. thats dropping the clutch at 4500 -5500 rpms
Old 11-12-2007, 04:45 PM
Bryan @ Speed Inc.'s Avatar
high teens is what i've seen works best with a few different brands, and sizes of d.r.'s
Old 11-12-2007, 05:12 PM
chrismorales75's Avatar
Best way to find out what's right for your car/tire combo is to play with the pressure and see the effects, personally I would want the best 60 ft, stable driving without losing mph on the top end.
Try up or down a couple psi, and run whatever gives you the best launch. There is no magical number, you can build two motors, two cars, same exact setup part for part and each one will require a little different tuning, just the way it is.
Old 11-12-2007, 06:25 PM
Taubr Unit's Avatar
I know everycar is going to be different but really the question is what is TOO low and will start ruining the tire or making it shake. Doesnt the radial tire have a stiffer sidewall compared to a et street/drag?
Old 11-12-2007, 07:10 PM
FASTFATBOY's Avatar
I run 12 psi in my 325 BFG's, anything higher and it shakes. BUT these tires are 3 years old. I just bought some M/T's...will test them soon.
David
Old 11-12-2007, 07:47 PM
gator's 99TA's Avatar
you will KNOW when the tire pressure is too low! lol. it will shake the fillings out of your teeth and you might break some driveline/suspension parts.
Old 11-12-2007, 09:24 PM
NA$TY-TA's Avatar
16 Cold here. 325/50 M/T's....
I have some more testing to do..... I am dieing to try the 295/65's
Old 11-12-2007, 11:23 PM
djsanchez2's Avatar
The very least i have seen any drag radial tire run at is 12psi which didn't work too well. The like to be in the 14.5-20psi range.
Old 11-13-2007, 08:23 AM
  #32
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,175 Likes on 764 Posts
I think start at 15 or higher, I think lower than that is problematic.
Old 11-13-2007, 08:43 AM
  #33
cam
cam's Avatar
At 16 psi there was no shake at all it was smooth as butter but it didnt really bite very well on my car. The difference from 16-13 was dramatic. Yeah it chugs a bit but it makes it bite hard for me. I did make one great pass at 14 psi although it was only one out of four and less shudder.
Old 02-05-2008, 12:20 PM
  #34
James Montigny's Avatar
18psi has worked best for me on 15x8s with 275mm ET Street Radials
Old 02-05-2008, 04:54 PM
  #35
Z-RATED94's Avatar
275/50/15s on a Bogart 9 3/4 inch rim. 20-22lbs. hot. Then again, not much HP here.
Old 02-05-2008, 05:22 PM
  #36
patriotformula's Avatar
Ive had descent luck at like 15 psi... 1.6 60' on a stock suspension car...
Old 02-05-2008, 07:36 PM
  #37
NJSPDER's Avatar
the correct answer for tire pressure is whatever works on your car. not everyone or every car will work at the same psi the same way.
play with your PSI and your launch, start high and keep lowering them until your 60ft's stop improving.
even once you found that happy pressure you will still want to play with it a little on time shots sicne different tracks and different weather conditions may bring different results.
