area infront of shock tower
Chris: When I get the car back form paint and have a few acessories on I'll start a build thread. This site, as well as others, are great for stealing ideas. Take any and all of mine, as I have done.
Yeah, one could cut the frame back much further, but again I had plans for mine...they fell threw...wanted to make a tow bar/hook that I could clamp on/around easily through the fog light holes.
A tow bar will be good when your pile breaks the first time out LMAO.
Post some more photos of your build up.
I am weighing everything I am taking out, I am over 60 pounds of removed metal from my mini tub project, will weigh everything before I put it back in, since removing all of the factory tub I am thinking 40 pound weight savings easy.
just use some GM zip ties, they should be located inside your glove box from the factory
Probably right, but I'd much rather be safe. Per NHRA rules a fuel cell needs to be mounted inside frame rails or "caged" w/ 1 1/4 DOM tubing if outside rails. Hood mount stuff I used 5/16 bar, then mounted all tabs to it. I've seen cars w/ much bigger/bulker mounts like 1/2. I would say that might be a bit excessive...to each his own.
