My new drag toy. 93 lx coupe carbed LS1/th400. (pics)
I bought this car off of "PRAY HDR" a fellow Tech guy. It already has a lot of the work done. Just needs a few things here and there and some bugs worked out on it. I have a new coan th400 with rmvb and a brake. I'm putting in it. The car came with a NIB TCS 4K to 4.5K.
Here's a break down of the car.
FRT Susp.
PA K member and arms.
strange coil overs.
Manual rack.
Manual brakes.
sn95 spindles.
sn95 dual piston calipers.
Rr Susp.
Built 8.8 with spool and 4.56, Ultimate 8.8 girdle.
Aluminum LCA's.
UPR adj uppers.
strange shocks.
UPR anti roll bar.
Engine
383 eagle rotating assemble
diamond -2cc pistons.
Roll master double roller.
LS6 ported pump.
ASP pulley.
Maziere race pump.
T-rex cam 110lsa.
AFR 205's 58cc chambers, 8019 springs(650 lift).
Yella Terra ultra lite adj 1.7 RR's.
Caddy racing lifters.
Vic jr intake.
750cfm mighty demon carb.
MSD 6LS ignition box/MSD super conductor wires.
Kooks 1 7/8"x3.5 headers.
3" True duals X pipe with bullets dumped at axles.
Trans
Coan th400 rmvb with a brake
TCS 4K to 4.5K converter.
hurst quarter stick with pistol grip.
Wheels/tires
weld drag lites 15x8/15x3.5
Hoosier QTP 27x10.5x15
I have already been gathering some parts to get the car ready for this coming year. I am trying to keep this on a budget of $10K. (EDIT 1/09) way past that now!!!!
I will keep you guys up to date on the progress this winter. And I am going to need a lot of help and advice along the way!
This is the reason I de modded my SS. To help fund this car. Now I will just enjoy the camaro on the street, as a street car and not beat on it.
FRT Susp.
strange coil overs.
Manual rack.
Manual brakes.
sn95 spindles.
Rr Susp.
Aluminum LCA's.
UPR adj uppers.
strange shocks.
UPR anti roll bar.
Engine
LS6 ported pump.
ASP pulley.
Maziere race pump.
T-rex cam 110lsa.
Vic jr intake.
Trans
Wheels/tires
The car already has the hvac system removed, frt bumper support in favor of a CM tube bumper bar. Very light and still ads support.
List of things I still want to remove.
wipers/wiper motor and arms.
power steering pump and rack in favor of a FR manual rack.
My goal is to run mid 10's on motor and mid 9's on the dope.
I'm not real sure what it's going to weigh after all the work and the CM cage. But the guy I got it from said it was around 2650lbs the way it was. I'm hoping for no more than 2800lbs. I think thats realistic.
nice!!! i've always loved that car.
as for suspension, tq box plates and cage needs...check out wolfe racecraft. really nice stuff, good prices and great guys to deal with...we've used all thier stuff on a buddies fox and it's all been great stuff...
also, do you know how the steering wheel is set up? we've been looking at doing a removeable wheel in my buddies mustang, but i haven't seen one up close yet...
As far as the steering, I have not looked at it closely yet, but it looks to be an adapter that slides on the stock shaft or it's welded under the trim panel were the shaft goes down through the column.
I am a body shop owner, so I will have a killer paint job on it after it's up and running and all the chassis work is complete.
I'm going to paint "Built Ford Tough With Chevy Stuff" on the back of the deck lid. LOL. My Ford buddies will be pissed!!!
Well I tried to fire up the mustang and it would not fire. It seams there is no tach signal. The MSD box has a power and two grounds and a yellow tach wire. And a few GM plugs for coils and crank sensor and cam sensor.
I have power and ground but no rpm signal.
I called MSD and they want me to try and return it or send it in for repair. There's going to be another few weeks before I can hear it run. Bummer.
So I'm going to focus on other area's the next few weeks.
1.get the carpet and seats pulled out and ready for the cage work to be done. in 3 weeks I'm getting a CM 8 pt with through the floor SFC's.
2. Weld up the anti roll bar and TQ box plates.
3. Remove old SFC's that are bolted/tach welded in. Through the floor's going in.
3. Replace upper control arms with adj UPR's with rod ends.
4. Start removing PS rach and pump. For a manual rack.
This will be about it for the next two weeks. I will take pics along the way!
man i have always wanted a notch with a ls1 but dont have the time or place to do it
i miss my 87 notch with 347 it was a fun car as well. im just spoiled by the ls1 now but am very partial to the fox notch
