Thinking ahead, how to set the vacuum on my Star vacuum system?
I hope to start putting my motor back in tonight and HOPEFULLY start working on mounting the vacuum system Friday. So before I get myself in a slump/bind/etc., I want to know beforehand how am I going to set the vacuum on my Star vacuum pump system? I bought the optional adjustable regulator that is adjustable by simply moving the nut one way or another.
LS1Tech Sponsor
You need a vacuum gauge on the valve cover to see what the pump pulls. Then rev the motor up to around 3500 rpms and see what it makes. I normally try to see 4-5 inches at 3500 rpm. Then go to the track and try to see the gauge going down track. I dont like to see more than 10 inches at max rpm.
See, I was already wrong. I was thinking 12-15 inches.
I'm pulling the vacuum from the valley cover. I cut the vent off, filled it in (aluminum weld), drilled a hole and welded a -12 AN fitting on the valley cover. So that's where I have it hooked up at.
My valve covers (GMPP) have no openings other than the fill cap. So where shall I put it?
I can ask, my buddy builds motors, the 406 with 18* heads runs a vacuum pump, it has a little breather with a valve he turns to adjust the vacuum. I'll call ask ask.
7 Second Club
I had my old setup alittle different, valve cover went to catch can, catch can went to pump, pump went to air. I was trying to keep the oil out of the unit which makes the rotors stick in the housing or come out slower. I had a 1/8" Barb on my catch can that I put a vacuum guage on.
