Drag Racing Tech
is a panhard bar needed for drag racing
Old Jan 7, 2008 | 02:38 AM
droptopT/A's Avatar
Default is a panhard bar needed for drag racing
will it help with anything
Old Jan 7, 2008 | 02:57 AM
RAGENZ28's Avatar
Panhard bar centers the rear end, do you have to have one? No, but you have to have something to locate the rear end in its place if you don't run one, wishbone, track locater or something.
Old Jan 9, 2008 | 06:41 AM
quickta's Avatar
Default panhard rod
how about the upper one, how many have just removed it,
was thinking of just removing it
Old Jan 9, 2008 | 07:41 AM
Fireball's Avatar
upper one is a support. many remove it for drag racing
Old Jan 9, 2008 | 03:53 PM
RAGENZ28's Avatar
I removed my upper support.
Old Jan 9, 2008 | 05:20 PM
9sec93's Avatar
take it out and let me know how it goes. j/k, you might want to leave the panhard bar in there. the support on the other hand, you can remove.
Old Jan 9, 2008 | 06:33 PM
NJSPDER's Avatar
a panhard is always helpful in some regard. in racing you want an adjustable no matter the application to be sure that the rear is properly centered and square under the car. that is the only way to make your suspension work 100%
Old Jan 10, 2008 | 11:23 AM
XX11SECZXX's Avatar
you can remove the top bar? will it affect the panhard bar at all? that would have been nice to know while building my exhaust.
Old Jan 10, 2008 | 12:15 PM
rtk434's Avatar
I have run my car without the upper bar for many years. On a drag car the panhard does not see alot of side load so the brace isn't really needed. I drive my car a good amount on the street and have had no issues. On a road race car or a street car that does some high speed cornering I would keep it.
Old Jan 10, 2008 | 03:32 PM
quickta's Avatar
Default panhard rod
so it I have to drive down interstate to get to the track, I should just keep it on?, I have the BMR upper one
Old Jan 10, 2008 | 04:05 PM
ONEBADWS6's Avatar
Keep the upper, when your car starts to leave hard it will need the extra support to track straight.
Old Jan 10, 2008 | 04:13 PM
quickta's Avatar
I didn't know it was that crucial, I guess I will leave the top one on
Old Jan 10, 2008 | 04:38 PM
RAGENZ28's Avatar
I've never seen a drag race car that uses a panhard rod as a locating device use a panhard brace.
If you make a custom drag race car, order a panhard rod, they don't send you a brace.
I welded around my panhard brace, narrowed it some and moved up the mounting hole then boxed in the outside, it's pretty damn strong.
If you're trying to make some super fast drag car run a wishbone, if this is your street car you wanna drag race some and remove weight, toss the brace.
If I crash and kill myself because the panhard rod brace was removed I'll make sure some one posts it for me
Old Jan 10, 2008 | 08:27 PM
ONEBADWS6's Avatar
Well my car cuts 1.29 60fts on HP, the car was pulling to the left for no reason despite adjustment. We put the upper brace back on and the problem went away.
Old Jan 10, 2008 | 10:24 PM
RAGENZ28's Avatar
That's my point, a fast car running 1.29 60fts yeah it might be a good idea to have it on.
On a street car that goes to the track once in a while and knocks off an 11 sec pass, I think it's just dead weight at that point.
You can always reinforce the stock mount since at that point a lot of people are not using stock gas tanks and run anti roll bars up top or have the stock gas tank removed, you can triangulate it with a piece of tubing.
Also did you weld yours on? You know that thing is held on by spot welds here and there right?
I am surprised it didn't fall off running 1.2 60fts held on with spot welds, that's why I welded mine all the way around and boxed in the out side and welded it to the side of the frame when I put tubs in the car, mine isn't moving unless it twists 1/2 the frame with it
I boxed in the outside of mine with 1/8th" and ran the piece up the the side piece on the frame to tie it all in.
Attached Thumbnails is a panhard bar needed for drag racing-0188732-r2-016-6a.jpg
