What ET ? With My Set Up?
Engine:
Iron 408ci
Stock L92's W L76 Car Intake NW 90mm TB
248/258 .647/.647 113+3
Comp 921 springs
TSP Push Rod's
LS7 Lifters
Comp Double Roller Timing Chain
Melling Oil Pump
Power Bond 25% Under Drive
Meziere Electric Water Pump Street Version
Exhaust:
Elderbrock LT's ORY Borla Xr1 Race Muffler
Fuel:
42lb injectors
Fast Fuel Rails
255 in tank pump with hot wire kit
Trans:
TH 350
JW Ultra Bell
Transbrake
Fuddle 3500
Yank trans mount
mad man dip stick
Rear:
Moser 9"
31 spline axles
3:89 gear
Spool
Suspension:
UMI Panhard Rod ADJ
UMI Sub Frame Conectors
UMI Torque Arm ADJ
BMR LCA's ADJ
PA Racing K-member
PA Uper and Lower A-arms
QA1 "R" Front Struts
Air Bag Pass Side
Wheel/Tires:
Weld ProStar's 15x10 rears w 325-50-r15 MT Radials, 15x3 fronts
Weight Reduction:
No HVAC
No Front Bumper Support
No Washer Fluid Tank
No Smog Pump
No Front Sway Bar
Rear Seat Delete
What do you think ? I dont have any dyno numbers yet but the car feel's really good.
I might send my fuddle back a get it restalled what would you guy's think about that or should i just sell the one i got and buy a new one ?
Adding more converter will help on the motor but if you built this for a fast street car you race at the track it will suck *** to drive on the street.
We cruise around in our nova once in a while and it has a 6,000 stall with a power glide, granted it makes almost 800 hp N/A, but still it is just impractical driving on the street.
If you would possibly spray nitrous leave the converter, if you want a happy medium 4,500 is good I had a 4,500in my old pile 377 sbc on nitrous and it went 1.30 on the bottle, all out motor consider 5,500.
anymore input with new info for just on motor 4200 stall ?
Thank's 408ssa3
Keep in mind which I don't recall anyone mentioning, the lower you activate nitrous the more toque it will make, yes your car will work better with a higher stall on the motor to keep it closer to the peak torque, but when you activate nitrous, that is your peak torque.
Adding 200 hp of nitrous at 4,200 is going to add a lot more torque than activating it at 5,500.
Im taking the car to a 1/4 track this weekend i'll post up the results.
Thank's 408ssa3
