Want to run 10.90s/ Super Street
In order to run 10.90s at sea level still be able to drive the car 30 miles to track, which heads, cam, converter etc. do you recommend and can it be done..(no nitrous)Thanks
Retired Street Racer
AFR or Trick Flow out-of-box heads, 230/236 .592/.602 112 LSA cam, Yank PT4000 stall, and a 275/50/15 MT Drag Radial. Since it is an '01 you should have the LS6 intake, so get your stock TB ported. Throw on an underdrive pulley and get a tune from a reputable shop. You will have 10.90s in the bag.
LS1Tech Co-Founder
My Camaro has run 10.92 at 3350 raceweight. I'd say:
28" tire for consistency, 4.10 gear in a 12 bolt or 9", T400 for consistency and the transbrake, TFS or AFR 215cc heads, 23_/23_ or 24_ cam, Fast 90 intake, 90mm TB. I'd run a 4500-5000 stall or run maybe more gear.
Anyway, you definetely want a trans brake and you don't NEED a delay box or throttle stop but it's a whole lot easier if you do.
you needto go alot faster than that, my dad ran 10.20's for years in Super street and was actually 12th in the natl' points, but he was gettin chased alot, now hees gunna be running 9.30's if he decides to go alky, or 9.70's if he stays gasoline and hees still gunna run superstreet. Basically just because your car can go 10.9 doesnt mean you can run and be good in the class.
