Beck Intake Users
What type of bellows or air cleaner setup do you use? This throttle body points downward at a good angle which seems like it would be a sumbitch to get a bellows on with a maf pointing down then have to go back up to the lid which points downward also,and there aint a whole hell of a lot of room.
I dont see how you will get a MAF in there unless you chop off the end of that throttlebody.
Or go with a speed density tune and just put a rubber 45* couple on there. Yout TB is where my MAF is sitting. At about the same angle.
David
Just imagine what it would be at 150 mph, yes it helped with the ram air, but a small hole say the size of a license plate would be suficent. I will try and fab another ram air for the current combo, when I get time and do a back to back test to see if it makes positive pressure on the big end.
Not sure if the drag would hurt though, if the air isn't getting backed up there and is getting inhaled by the motor, it may not hurt..... something to think about.
its a 6.0 iron block 408, callies magnum xl crank, oliver billet rods, and wiesco pistons, afr 225's that have a little port work done. the beck intake with the direct port system it has a comp cam, hydraulic roller 254/258 647/647 on a 112 lsa, ati converter, rossler th350 with a t-brake, ford 9", full suspension, and it is completely gutted
thanks,
david
