4 Wheel Line lock?
You could do what you're thinking about doing, with a 2nd line lock. You could wire them so a button will put both front and rear active, and still have a switch to activate just the front for the burnout box.
Not a pretty site!
Personally I wouldn't leave off a line-lock in an automatic car. All the time needed to set or pump the brakes before grabbing the switch before letting go, plus depending on launch rpm the car could "push" versus the transbrake which locks first against reverse so the car will stay at rest. I'd footbrake it and then try the trans brake when funds allow. Believe me when I say you can beat "box cars" with a footbrake ride.
Nothing like Failing Tech at a division race that is running at your home track
Of coarse two years later they banned electronics
Even if you can or don't get caught. Using a line lock on the rear is not very consistant. There have been a few threads around, & brakes just don't release as consistant & quickly as a transbrake. I never tried, just what I read.
