Drag Racing Tech
stock brakes dragging
Old 03-03-2008, 11:05 AM
daniel6718's Avatar
Default stock brakes dragging
wondering how you guys cure this...ive got stock ls1 brakes with carbon metallic pads and i can bleed them and with them in the air get like 2 turns with them...
run it a few days and then i cant get them to spin 1/2 turn
im using basic dot3 fluid...and im thinking it gets hot when im sliwing down and its boiling inside? is there any other way to keep them from dragging? will some dot4 help?
Old 03-03-2008, 11:12 AM
DMH Fabrication's Avatar
My stock ls1 brakes work fine and dont hang up like that. Maybe you need to work the pistons in the calipers in and out a few times? Also, if you have a manual master cylinder, make sure its adjusted correctly but that would cause it to drag all the time.
Old 03-03-2008, 11:49 AM
daniel6718's Avatar
no its stock brakings system front to back...
ill work the pistons some...
btw i tried to pm you...its sent pm me back when you get it
Old 03-03-2008, 12:34 PM
oh ok. I had just sent you a PM about it lol. I cleaned out my pm's now btw.
Old 03-03-2008, 06:04 PM
kevredz's Avatar
I've noticed drag on my fronts. I get about 1/2 turn. Don't know how to fix it though.
Old 03-03-2008, 06:23 PM
FASTFATBOY's Avatar
All 4th gen brakes drag.
David
Old 03-03-2008, 06:42 PM
daniel6718's Avatar
David
not true my gf 02 ss is daily driven and when we had it on the lift the other day i spun them an it would go 6-7 times....
Old 03-04-2008, 12:31 AM
StreetStalkerZ's Avatar
Me and a buddy did mine a few weeks ago. Mine would not turn a 1/4 of a turn on the fronts and was dragging big time! The fix was a set of steel braided brake lines. I got the front and rear setup for around $100 at summit racing,worked like a charm! Now they spin like crazy
What is happening is your stock rubber brake lines are collapseing and causing the calipers to stick at all times and not releasing like they should. You can't collapse steel braided brake lines without cutting into them. It feels like i have a set of new brakes on the car.
Old 03-04-2008, 01:21 AM
realmendrivev8s's Avatar
interesting, im going to have to go ahead and do that.
Old 03-04-2008, 03:13 AM
JUICED96Z's Avatar
Braided is the way to go.
My 96's brakes did not drag so I would not say all do.
The front brakes on my 83 draged on the way home after I bought it, locked up the left front and almost put me in a ditch, seals in the calipers were shot and the rotors were done, everything but the lines was replaced......... Going to swap the lines over to braided this winter. Manual brakes also.
Old 03-04-2008, 03:28 AM
gold98Z28's Avatar
it is most likely the flex brake line's. you dont have to go to steel braided(tho it is a good upgrade) but you do need to replace them. new stockers will get the job done, i went with earl's stainless steel kit. not only fix's the dragging it give a better feel to the brakes. the lines dont exspand like stock rubber lines under hard braking. and takes some of the ABS thump out in the event the ABS is engaged.
Old 03-04-2008, 10:39 AM
daniel6718's Avatar
im not goana so braided lines when drag brakes are next winters project
Old 03-04-2008, 12:27 PM
gold98Z28's Avatar
huh???????????
Old 03-04-2008, 12:52 PM
daniel6718's Avatar
goana put on some aerospace drag brakes prolly late summer so im not goana do braided lines now...i dont think its hurts that bad
