Drag Racing Tech
Rear shock question
Old Mar 8, 2008 | 05:58 PM
1_bad_TA's Avatar
Default Rear shock question
I have a 2002 Trans Am. I'm wanting to change the rear shocks over to Comp Engineering 3 way rears. I went and looked at a set today and they are tad longer than the stock shocks. We looked it up in the Comp Engineering book and it says up to 99. What is the difference in shocks from a 99-02 and will that little extra length hurt anything? The car isn't lowered and I'm staying with the factory rear springs. If someone could help, it would be much appreciated.
Old Mar 8, 2008 | 06:19 PM
snake charmer's Avatar
not sure man i thought they were about the same . only thing i could think is size of rim but i got a 00 that came with 16s .
Old Mar 8, 2008 | 06:45 PM
mattraypharbor's Avatar
I bought kyb gas adjust shocks there realtivily cheap and they cut my 60 by a tenth over stock and the ride on my pro kit droped car its not the most radicul drop fro eibaich its the other one i think pro but it rides 100 times better over stock...
Old Mar 8, 2008 | 07:16 PM
1_bad_TA's Avatar
Anyone with a answer?
Old Mar 8, 2008 | 07:18 PM
getusumws6's Avatar
how old was the catalog ?
Old Mar 8, 2008 | 07:22 PM
1_bad_TA's Avatar
not too sure. Even on Comps site it says up to 99
Old Mar 8, 2008 | 07:24 PM
1_bad_TA's Avatar
here is a link to their application section.
http://www.competitionengineering.co...&CatCode=10032
Old Mar 8, 2008 | 10:00 PM
BOLO's Avatar
CE pn#2700 3way adj. shocks should work on all 93-02 Fbody. I run them w/stock springs.Your rear springs on your should be no different than mine.
Old Mar 8, 2008 | 11:26 PM
1_bad_TA's Avatar
Have you had any issues with the shock bottoming out? When I compared them to a stocker, they were alittle longer. I'm not lowering my car at all, do you think I should worry about that?
