Drag Racing Tech
TA bumper support prototype from Burkhart
Old Mar 17, 2008 | 06:44 PM
  #61
JL ws-6's Avatar
Race your car!
I placed my order this morning with Chuck, for the front bumper support and the manual master support.
K member will get ordered end of the month.
Old Mar 17, 2008 | 09:47 PM
  #62
LS1SpeedAddict's Avatar
Is there any cutting involved to mount this? Is it a direct bolt in replacement?
Old Mar 18, 2008 | 08:34 AM
  #63
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Just talked with Chuck.....payment going out this weekend!
Old Mar 18, 2008 | 08:55 AM
  #64
Steve Burger's Avatar
LS1TECH Sponsor
This is a direct bolt in. The frame rail holes need to be drilled out a bit and that is it.
Old Mar 18, 2008 | 04:23 PM
  #65
LS1TECH Sponsor
We have 5 confirmed orders and one maybe. Get your orders in before the introductory price goes up.
Thanks to all that have ordered so far.
Old Mar 18, 2008 | 05:48 PM
  #66
1_bad_ss's Avatar
Mine was the 2nd one ordered do you know when the jig will be made and these will ship roughly
Old Mar 18, 2008 | 05:58 PM
  #67
Originally Posted by Steve Burger
For the bottom, we can add tabs for thr bottom, but....
I only have 2 things I need to know before I place my order, can I get mine with those tabs so I don't have to cut into my front bumper? Also in some of the pictures the bottom bar isn't welded completely to the plate that bolts to the car. Will the production models get welded completely?
Old Mar 18, 2008 | 07:25 PM
  #68
1_bad_ss's Avatar
I don't think you have to cut the actual bumper I think it is just the air deflector you have to cut, but I could be wrong. I hope I won't have to cut my bumper
Old Mar 18, 2008 | 08:26 PM
  #69
JL ws-6's Avatar
Race your car!
The only part that you will have to cut is the flap that is pinned up to the stock support. The bumper cover actually has a line molded into it on this flap, which would work absolutely perfect as a cut line to trim the cover. ls1 speedaddict, the photo in your sig, right above fbodycentral, you can't even see it, but that flap of the bumper cover, that is what you will need to remove.
It's about 3 lbs too, and will allow plenty of air to get to the radiator, allowing you to remove all the plastic that aim's air at the radiator, another weight savings. The braces that go up to the top of the bumper cover allow you to remove the big plastic piece that goes across the front of the car, and the metal piece that attaches the plastic piece to the hood latch. Probably another 5 lbs.
This 12 lb piece, allows you to pull by my guesstimate another additional 15 lbs off the front of the car that you normally wouldn't be able to take off if you just removed the bumper support and the foam. And, the nose of the car will be nice and solid again, and allow better cooling.
For a race car, this is a no lose situation, and I'm sure once people see this part installed on some cars, the orders are gonna come flying in from every guy that's racing one of these cars.
Old Mar 18, 2008 | 09:08 PM
  #70
Joe99SS's Avatar
Thanks for all of the help Steve, ordering mine in the morning.
Old Mar 19, 2008 | 08:49 AM
  #71
LS1TECH Sponsor
The bottom bar will be welded completely. This is a prototype in the pics. It is a representation of the real product. The real version will not have the slip tubes and will be fully welded. Once we get a the current orders out we will work on the tabs at the bottom if needed. The best thing to do is take a cut off wheel and zip off the plastic for the bottom tabs. It will save weight and not hurt anything. You could leave it there as well. It still won't hurt.
Old Mar 19, 2008 | 08:51 AM
  #72
JL ws-6's Avatar
Race your car!
Cutting it off will allow more air to get thru without the plastic ducting that directs air at the radiator, and should provide better cooling.
Plus, the 3 lbs you cut off will only help with weight reduction
Old Mar 19, 2008 | 08:56 AM
  #73
Ok you guys sold me on it, I'll probably place my order sometime today.
Old Mar 19, 2008 | 11:22 AM
  #74
Joe99SS's Avatar
Ordered mine with Chuck today, thanks again!
Old Mar 19, 2008 | 11:46 AM
  #75
romoranger's Avatar
do you need all that plastic crap in front of the radiator with this, or do you not? after reading a few posts I am unsure
Old Mar 19, 2008 | 11:48 AM
  #76
JL ws-6's Avatar
Race your car!
you can leave it, but you can take it out for a little more weight reduction. I would leave the plastic on the bottom in the corners of the bumper cover to help keep it tight and not allow it to flop around at speed.
Old Mar 19, 2008 | 12:08 PM
  #77
LS1TECH Sponsor
I dumped the corner plastic years ago. No issues.
Old Mar 19, 2008 | 03:27 PM
  #78
DanZ28's Avatar
Just talked to chuck and ordered mine for a LS1 Camaro.
Dan
Old Mar 19, 2008 | 03:32 PM
  #79
Just placed my order with chuck for a black powder coated one
Old Mar 19, 2008 | 04:22 PM
  #80
DanZ28's Avatar
Must have been you calling when I was placing my order .
