TA bumper support prototype from Burkhart
The support weighs 12 ponds in prototype form on our scale.
We did get the fog light mount included. If no lights are needed we can add a tow hook.
Let me know what you think.
More pics at:
http://upgradeadvantage.spaces.live.com/
Can the factory hood latch still be used, for us clowns that haven't gone to a pin on yet? Also, it looks like you can remove that top plastic piece the bumper's attached to with the pop in pins, yes? Lower part looks to be set up the same way too?
The way this is set up, you can cut off the flap of plastic the bottom push pins use. This will save about 3 more pounds of weight. The bottom bar rides along the nose and the lower part. It is very stable and sound.
I'll add one of these onto the front end order, **** at the rate it's going I might come in at enough to get the next level of discount LOL.
The fuel cell with just be a generic 3 gallon. Nothing specisl. We will however make the brackets for whatever Chuck gets to test with. We can offer the cell as an option.
Bare metal saves us turnaround time as well. It should also be about 20.00 cheaper.
The foglights will bolt on with 2 supplied 6mm bolts. The only mod you may need to do is drill out the bolt holes on the frame rail. We would like to use a little larger bolt. Other than that this will be a simple bolt on.
Getting the cover off and on with this installed is easy. Chuck and I did that about 100 times yesteday making this thing up.
We will offer a rear kit as well. It will be a simple bolt on bar that goes between the frame rails. OR do you want something more elaborate like the front part?
Bare metal or black powder coat here.
