Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird NHRA Safetly Requirements<br>Important information to help you understand your Camaro or Firebird.
"What do I need for.." Safety Requirements for NHRA (Rollbar, Rollcage, harness, etc)
#81
Race your car!
Correct. Noone really enforces it on a factory seat, as there's no real way to do it without hacking the seat up.
But, if you were to have a stock seat in a car going bottom 8's or something like that... I have a feeling someone would be saying something.
Kind of reminds me of a 73 nova I saw at lebannon valley one time. Car was running 10.40's, with a n/a small block, had an 8.50 cert cage in it with the stock bench seat in it.... I know there wasn't any braces on that. But, I think that same car, with a couple kits on it years later was going somewhere in the 8.70 range... because I remember hearing about him getting some flack about the bench seat.
#87
I was talking to Jeffco transmissions about there 4 speed and Bruno drive and he mentioned about a 6.3 cert. For the bell housing because I run a roots blower. Looking in the rule book the way I read it is a 6.3 cert. If you have a roots blower and a clutch. Well the Bruno drive is a torque convertor. So would I need a 6.3 or the 30.1 bell housing? I see they do make a 6.3 bell housing for the Bruno though?
#91
The NHRA rulebook info online(nhra . com) says, for 2013, a parachute is required for cars reaching at least 150mph and is listed as required only in the 9.99 or quicker brackets. So unless they made a really recent change and didn't bother to update their own rule book, I'm in the column of, "you're right and he's wrong."
#92
The following users liked this post:
N_White04076 (09-10-2020)
#93
They are going in a 69 Dart......
#95
#96
So if I wanted to buy a helmet for a high 11 second car I should look for a SA2010 and it will be good until 2022 correct, 12 years. I'll be lucky to make it to the track more than once a year. I read on smf.org (Snell) that the SA2015 helmets are not allowed to go on sale until October 2014.
#98
Location: Palmdale, California - 701 RWHP 582 RWTQ - 1/4 10.34 @ 135 MPH
But to answer your question in short - Yes!
WOLFE Racecraft makes bolt in 5 and 6 point set-ups that NHRA qualify for 9.99 seconds (most tracks will be lenient and let you go faster)
WOLFE also makes weld in cages too that will put you in much lower second classes as well!
http://www.wolferacecraft.com/
I have their 5 point bolt in cage with removable door bar my C5 Vette which is approved to 9.99, however like I said they are a little lenient and will let you run faster!
Thanks,Matt
#100
