Drag Racing Tech
Lingenfelter Launch Control (2-step)
Old Mar 9, 2010 | 10:19 PM
  #181
nick y's Avatar
Originally Posted by nick y
is the retard only activated by 12v or ground? rpm doesnt need to be trigggerd too? wanna use the retard portion only for shifting and retard and two step for launching. i have lingenfelter speed sensor to switch off two step @ 1 mph.
think i answered my own ?????
The Timing Retard function can be used by itself or while the launch control RPM limit
Old Mar 10, 2010 | 08:15 AM
  #182
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default LPE 2-step and timing retard activation
On the LNC-002 the retard is activated by +12VDC on the orange wire or by the MAP sensor input. It is not ground activated.
On the LNC-0002 the 2-step is activated by by either +12VDC (yellow wire) or ground (green wire).
The timing retard is active when ever it is triggered by the orange wire or by the MAP sensor input AND when engine RPM is over 1000 RPM. The RPM setting for the 2-step function does not impact the timing retard activation.
