Drag Racing Tech
a/c box?
Old Mar 17, 2008 | 05:59 PM
chevyls1's Avatar
From: where ever i can store my car. (palos hills,il for now)
Default a/c box?
ok i am removing the a/c from my car. the big box on the firewall (evap core) is the heater core in there, can it be removed and but leaving the heater core?
thanks
cliff
Old Mar 17, 2008 | 06:40 PM
John_D.'s Avatar
The heater core is in the half of the box on the inside of the firewall, under the dash.
You have to cut the box in half to get rid of the outer half, and put a blockoff plate in the big hole in the firewall. There are some threads and pictures on here about it.
Some people just run an aftermarket heater, and do away with all the stock parts.
Old Mar 17, 2008 | 06:57 PM
chevyls1's Avatar
so you car run the block off plate and heep the heater.
Old Mar 17, 2008 | 07:55 PM
Dave J's Avatar
I took mine out and the blockoff plate I mounted the coil to it
http://www.flickr.com/photos/1551097...84911/sizes/l/
Old Mar 17, 2008 | 08:36 PM
chevyls1's Avatar
how do you get the box off???do you have to pull the dash??
Old Mar 18, 2008 | 12:37 PM
John_D.'s Avatar
Originally Posted by chevyls1
so you can run the block off plate and heep the heater.
That's what I'm did.
You might be able to get it out without pulling the dash. I had my dash out already for some rewiring work I was doing.
Also, there is an extension to the heater box, that goes over the transmission hump, under the middle of the dash. There is one bolt from the engine side that goes right into the middle of that extension. Most people end up breaking that part of the box to get it out, since the bolt isn't accessible with the engine in the car.
Here's a long thread about this subject. It's in the LT1 section, but it applies to the LS1 cars too.
https://ls1tech.com/forums/lt1-lt4-modifications/711439-c-firewall-stuff-removal.html
Old Mar 18, 2008 | 02:29 PM
chevyls1's Avatar
thanks alot i was looking for a write up
