Drag Racing Tech
wheel studs with drag lites?
Old Mar 21, 2008 | 08:13 AM
stroked_408's Avatar
Default wheel studs with drag lites?
what length wheel studs should i get for rears? i have a moser 9 inch i'm running a 5/16 spacer i have the closed draglite lug nuts and i'm running 8's 5.5 in backspacing.
i'm looking at the arp 7708, how much longer are those than stock ones?
Old Mar 21, 2008 | 03:29 PM
getusumws6's Avatar
if you want to run 12mm studs the longest you can go is 2.5arp(i ran thoses on my rear stock 10 bolt for 2 years w/5/16 spacers) if you want to go at least 3", upgrade to 1/2 studs,they're a little bigger and will give you more turns on lug w/spacers
Old Mar 21, 2008 | 03:31 PM
getusumws6's Avatar
7708 are the 2.5" arp studs, they are longer than stock. not sure how much longer.
Old Mar 22, 2008 | 07:37 AM
Razor_Blade's Avatar
I don't remember the measurement, but here's pic with a side by side comparison.
Old Mar 22, 2008 | 11:01 AM
xpndbl3's Avatar
ARP makes a 12mm stud in 3.25" length, I have them on the front of my camaro
Old Mar 22, 2008 | 11:20 AM
1_bad_TA's Avatar
I'm using the 7708 for the front of my car. I'm running a draglite with a thin spacer. Going to be using the 3.25 for the rear.
Old Mar 22, 2008 | 03:12 PM
getusumws6's Avatar
they don't make that length for rear though.knurl size anyway. Edit:Mouth SHUT
Old Mar 22, 2008 | 08:16 PM
formula98ws6's Avatar
On my 9-inch I first had the short studs that moser installed. I then changed to the arp-100-7708 2.5 inch. I have now changed to the arp-100-7713 3.25 inch and put the 2.5 inch on the front. They both have a .509 knurl.
Old Mar 23, 2008 | 11:09 AM
xpndbl3's Avatar
what does edit: mouth SHUT mean?
also, i have put them on the back of 10 bolt rears as well, so I'm not sure what you mean by this?
Old Mar 23, 2008 | 12:13 PM
1_bad_TA's Avatar
now that i've read alittle, I will be using the 3.25 front and back.
Old Mar 23, 2008 | 12:19 PM
dlove's Avatar
longer never hurts
to pass tech, there must be the same length of threads showing as wide as the stud is.
