4th Gen BBC Project
On this board who can or can't afford it, who knows that's not my business who has money, but there are a lot of nice, fast cars around these days on a lot of boards and several of them are over the 2,000 hp range.
Personally I think a pro charger or turbo is the way to go these days but for the nitrous guys that motor would be a killer base to add some stages to.
It's not about being the hero of test and tune, if you want to be competitive in several classes these days, which are already over 2,000 hp you better put some money in your bullet and hope it fires when you stage it up
Even the drag radial classes are making big time power, a friend of mine right now is building a motor to make over 2,000 hp with a big centrifugal blower to run on a 275 60 15 drag radial. The days of making 500 hp and running a small tire and being competitive are long gone. Guys these days are all about big power and traction controls and boost timers.
Take a look at this video and you'll see what one of the milder turbo motor makes.
http://www.stevemorrisracingengines....r-engines.html
a true 10.5 car i believe.... runs 190ish mph i believe on stock suspension
thats no unicorn either... other cars do it.... crazy these days...
I think it is out of control and these classes make guys weigh 3,400+ pounds and they are up to 200 mph now, it's just getting out of hand, I would hate to see something 3,600 pounds crash at 200 mph.
My buddy is building a 2,000 hp blown setup and by the time he gets it done there will be someone else with 300 more hp running in the same class putting it down on the same 276 60 15 drag radial
these "street" car classes are becoming im possible to run in for some one even on a 30k$ budget for a whole car..... im not saying my car has 30K in it but its close to 20k-25k and im just shooting for 5.4x in the 1/8th... if that happens ill be impressed with my production gm BBC and a plate and fogger
The 10.5 outlaw and drag radial classes are going to be big money and very competitive, after a while it'll pretty much be a bunch of pro stock chassis with stock or modified suspension with everyone making over 2,000 hp. It won't be long before the 6 sec barrier is broke.
There is more than enough power out there, it is just the first person to put it to the ground, but whoever is the 1st 6 sec drag radial car is going to have one big name for a long time to come and I sure am not spending that much money trying to do it
I have no idea what my car will make or run but I am building it 25.2 full tube frame, 33.5 or 34.5x17-16 and trying to make close to 2,000 hp with twins on a old junk BBC
it runs what it run and takes as long as it takes to finish, one thing I know, it's gonna be one fun ride.
Still working on the headers. They no longer bolt up with the RHS heads like they did when I mocked up with the stock 990's. Hitting the k-member really bad so I'll have to relief cut them and bend them up so they will fit. I'm so glad they were only $150, lol. Eventually I'll get a set made, but I'm not at the point yet where I say screw it and buy a $1300 set of headers.
This thread has got me thinking. I've have this 598 E85 EFI 10/71 sittiing in the corner of my garage. Maybe I should do the same and put it my f-body?
Ulakovic22, that's looking good. Can't wait to ya get it fired up!!
-Dave
Nice! It will be a tight squeeze to get that blower to clear though and will probably require a lexan windshield and some generous trimming!
Installed the balancer, crank trigger and spaced out the alternator bracket so the pulley lines up.
Got the manifold on there with gaskets (dry) so I can mock up the throttle body again and make a template. I used an old one I made and it was really close so I think I'm good to go, just a few minor adjustments. I left it dry so I can pull it back off and prime the engine right before I start it instead of priming it and then letting it sit for a long time.
Anyway here are some random pics of stuff. Notice on the manifold how well the ports all line up. Yes I'm proud of how well I marked the intake
