4th Gen BBC Project
Now if you would have done this to your Nova, that would be bad to the bone since that is a unique and more collectable car that warrants a second look. But Camaros are a dime a dozen here near the 'Juana, so I have no clue why you would not stick with all the proven stock-style chassis stuff and build a bad ride that way instead of pumping time and money into all this crazy, one-off stuff.
Look at Madman, now that is a bad ride. Stock-based set-up, fast as can be.
Don't get me wrong, you did nice work here and everything is executed in a professional manner. However, did you ever justify the added weight and complexity of running a BBC when an LSX could have produced the same results?
It may be totally justfied and I am sure it is a fun ride, but I was just wondering what your thoughts were for going old school on the engine as opposed to going the more modern route?
Yes people run great with the LSX, but there is no substitution for cubic inches, a BBC may weigh more than an LSX, but whatever the weight difference is can be easily made up with more power.
The top of the line full race LSX might make 1000 hp on motor, big inch BBC's are close to 2000 HP N/A now, there is no comparison, without boost the LSX will never have the power potential of a big inch big block
5.080 BORE X 5.300 STROKE
NATURALLY ASPIRATED (NO NITROUS)
2030 HP @ 8100
1380 LBS. TORQUE @ 6500
2030 HP no power adders, no small block N/A is ******* with that
You keep the 200 pound weight savings, I'll take the extra 1,000 hp
2030 HP @ 8100
Great motor, no doubt. But not practical for someone who is not running a pro mod or IHRA pro stock.
I understand the ridiculous torque a BBC makes. But I also understand how it is a giant water heater. If you go race and have to hot lap the car, you will be boiling over. Been there, done that. Now put that monster on the street, not real practical.
a 9 second car requires a cage, window net, and parachute, sfi padding, trans shield, diaper.... list goes on and its not a "street" car..
I'm building something that has the potential to make 2,000 hp @ 6,500 rpm, will I ever use that much I doubt it, but I know one thing 1,500 hp on pump gas is nice, not too many LSX's with boost doing that.
I'm not knocking the LSX, I had one myself and loved it, but any motor is just an air pump and the bigger it is the more you can put in and get out. You just can't make the same power with a motor limited to a 4.250 bore compared to motors with bores that can go 4.60 and up, you can't build heads that flow what big block heads will simply because you can't build them big enough and can't run the big valves and ports a big block head can.
You make power three ways, spin a motor and ingest air, or force it in or chemically inject more into the engine. With out boost or nitrous you either have to spin it higher or make it bigger to make more power. I would rather make it bigger and keep the rpm low, it makes more torque and is easier on parts and valve train and ends up being a milder combo in the end.
I plan to run a little faster than 9's
Edit: If I had an LSx car I would have probably stayed with that, but since I had a LTx car the only way to get there was with a BBC. It will also be really cool to see peoples reactions when they see and hear the car.
2030 HP @ 8100
2030 HP no power adders, no small block N/A is f*cking with that
For this price, I'd buy two:
2008 SONNY'S DESIGN EXTREME PRO STOCK 860 CU. IN. 5.300" BORE SPACING 2030 HP " GM SEMI-HEMISPHERICAL HEADED ENGINE"
2030 HP @ 8100
BUY NOW THROUGH
JULY 1, 2008 !!!!!!!!
$86,900.00
http://www.sonnysracing.com/
2030 HP @ 8100
BUY NOW THROUGH
$86,900.00
