Drag Racing Tech
Installing pitpal cabinet on door, need help
Old Mar 25, 2008 | 05:17 PM
mdacton's Avatar
Default Installing pitpal cabinet on door, need help
How should I install this thing? The door seems to be hollow.....its a 08 haulmark 28' trailer....I think the side door is filled with foam.
Any ideas? I got #10 self tap screws with it but they dont bite anything other than the skin the door is wrapped in
Old Mar 25, 2008 | 08:19 PM
mrdragster1970's Avatar
6 & 8 Second Club
My Pace has metal vertical bracing. I screwed the heavy stuff into that. There must be something in there for bracing??
Old Mar 25, 2008 | 09:51 PM
mdacton's Avatar
Thats what I'm thinking too, I just need to find it somehow. There is no screws on the top or bottom just the sides.
I will figure something out tommorow, even if I have to take it apart to find out.
I did see somewhere they sell an aluminum hat channel kits to go from side to side...Might have to get that if I can't find the braces
Old Mar 25, 2008 | 09:53 PM
Navy David SS's Avatar
Re-opened at members' request
David
Old Mar 26, 2008 | 09:21 AM
Fireball's Avatar
would the braces be steel? if so use a magnet...
Old Mar 26, 2008 | 10:28 AM
Tireburnin's Avatar
I don't think there is a verticle brace. I think it is diagonal on most doors.
I would do two horizontal braces from the sides of the door.
Old Mar 26, 2008 | 11:08 AM
kp's Avatar
kp
Mine was the same way, I didnt put it on the door. But I have seen guys just pop rivet them on the aluminum skin.
Old Mar 26, 2008 | 12:26 PM
mdacton's Avatar
Well I don't want to do that, There seems to be nothing inside the door just an aluminum frame around the outside edge.
I found an install kit that goes from side to side...its aluminum hat channel, so I guess I will just order that.
Thanks
Old Mar 26, 2008 | 12:52 PM
6 & 8 Second Club
Should have mentioned, I've had mine many years. You can see the vertical screws. It's a '90's style steel trailer.
Forget how long I've had it sorry.
Old Mar 26, 2008 | 01:29 PM
mdacton's Avatar
Well I guess the newer trailer have "lightweight" doors.....
Found some kits if anyone needs them...
http://www.pro-lineperformance.com/P...20Cabinets.htm
number 319 the channel kit.
Just something else to order.....
http://www.pitpal.com/products/Alumi..._Kit-56-1.html
