Drag Racing Tech
installing kirkey seat
Old Mar 29, 2008 | 07:54 PM
K9Kev's Avatar
Originally Posted by BOLO
On the seat brackets you're incorporating, will it bolt on to the original mounting bolt on the floor?
Good question....I hope so too.
Old Mar 30, 2008 | 01:26 AM
lbz34's Avatar
In for two with crotch strap
Old Mar 30, 2008 | 02:15 AM
nickx07's Avatar
try looking up ed quey and taking a look at their 3rd gen seat brakets. they will bolt up to the stock seat studs and you could weld another peice of angle steel for renforcement and bolt an eyelet bolt to it and use those clip on crotch straps. my kirkey seats came with brakets that wrap around the seat and bolt together for adjustments. none for back and forth though and the ed quey mounts are stationary.
Old Mar 30, 2008 | 09:33 PM
gemballa996t's Avatar
i made these at my work, i don't have the measurements on hand but here are some pictures
Old Mar 30, 2008 | 10:12 PM
BOLO's Avatar
^ Very nice, can you make me one?lol^
Old Mar 31, 2008 | 04:03 PM
Steve Burger's Avatar
LS1TECH Sponsor
These will be bolt in and drop right on the factory studs.
Old Mar 31, 2008 | 06:13 PM
datsbad's Avatar
has anyone ever used factory non power seat tracks and made them work that way?
Old Mar 31, 2008 | 10:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I was thinking about that the other day too. You could use the slider mounts on the back and it would be completely adjustable.
Old Mar 31, 2008 | 11:10 PM
9sec93's Avatar
i have. all you have to do is drill your own holes through the seat and through the track and use some kind of spacer in the front because the bottom of the seat is not completely flat.
Old Apr 1, 2008 | 12:54 AM
Tapout911's Avatar
I made a square frame from 1/8' by 1 1/2" flat metal. It was then drilled and bolted to the manual seat sliders. Then I used the kirkey mounts for the seats and mounted them to the frame. Measurements depend on the hip width of the seat, but mine were 17 1/8" wide by 14" long. The kirkey seat mounts bolt to the side of the seat and were purchased from summit.
Old Apr 1, 2008 | 01:02 AM
OWN3D BY MY PROF!
Solution found. Do you have any pictures?
Old Apr 1, 2008 | 02:02 AM
  #32
9sec93's Avatar
i will get you a pic tomorrow afternoon, i am working nights right now and will probably sleep til 1 or 2 pm after i get home.
Old Apr 1, 2008 | 02:05 AM
  #33
9sec93's Avatar
that just sounds heavy and kinda defeats the purpose of the light-weight seat. it is nice to have the adjustability in a street-driven car though.
Old Apr 1, 2008 | 05:12 AM
  #34
dhpewterz's Avatar
I did the same thing but once you bolt it to the manual track it makes it heavy. thats why i was happy to see someone workin on these brackets for us.
Old Apr 1, 2008 | 11:57 AM
  #35
DADDY&GIRL93TA's Avatar
You can count me in on that
Old Apr 1, 2008 | 12:57 PM
  #36
9sec93's Avatar
i agree with ou on that. i used the factory track to mount the seat only to get it where i wanted it. after driving the car for awhile and being comfortable with where the seat was at, i made my own mount and did away with the factory track. i will get pics of both when my camera is done charging.
Old Apr 1, 2008 | 01:47 PM
  #37
dhpewterz's Avatar
cool. yeah i would like to see pics when you get a chance so i can get and idea of what i need. Thanks
Darren
Old Apr 1, 2008 | 05:29 PM
  #38
9sec93's Avatar
with stock seat track
new solid mount with extra tab in the middle for the crotch strap
Old Apr 1, 2008 | 11:07 PM
  #39
OWN3D BY MY PROF!
Thanks for the pictures. Basically, you just add a spacer to the front to accomodate the curvature of the seat and bam. That's pretty sweet. Even if you think the stock slider weighs a lot you're still loosing a ton of weight compared to a stock 35lb cloth or 45lb leather seat.
Old Apr 2, 2008 | 05:16 AM
  #40
dhpewterz's Avatar
yes sir thanks for the pics and nice shifter by the way its the same one i got lol
