Airbag vs Drag bar?
Now I have the Spohn drag bar, it definately was the key to my car leaving straight.
I actually have dual airbags as well. I have stock springs out back and I use the airbags to keep the car from squatting on launch instead of stiffer springs because I drive it on the street and didn't want the rough ride.
Old school junk maybe hehe, but it works. 1.29 60' best so far.
Mark
You could make one that's a drag style that will handle high cornering loads, you just use a little bigger tubing and larger links, rod ends and the 2 arms out of thicker material.
More front bar makes a car understeer more.
There are several sites that show the relationship of changing tire pressures, sway bars, springs, etc. on each end of the car to oversteer/understeer.
Here is one example: http://www.rallylights.com/other/stuning.htm
1 airbag I agree you wouldn't want to do that but 2 airbags for the above reason then yes.
Mark
edit": i used to run eibach drag springs and air bags=severe body roll---- wolfe w/ factory v8 springs=leaves flat
i gueass it also matters how much power you have.
I hear ya. I spoke to Spohn and they told me it was ok to run the bags as long as they were the same psi in both.
Maybe the wolfe is different, I don't know.
As long as it works right?
